Old 04-08-2010, 01:45 AM   #1
72gmcshorty
72gmcshorty's Avatar
Should i put lt1 into my 2wd blazer?
I have a chance to buy a motor/trans out of 96 corvette. Whats involved in putting this into a 72 2wd?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 04-08-2010, 11:28 AM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Should i put lt1 into my 2wd blazer?
I don't know what is involved in putting it in, but I say go for it!
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-08-2010, 06:08 PM   #3
72gmcshorty
after doing some research here it looks like it might be a little too complicated and time consuming. Going to stick with carb setup.
1992 Gmc 2wd
Old 04-08-2010, 08:57 PM   #4
cparman
sharp as a marble
The motor mounts are the same as what came in your truck. I personally do not care for that engine. The ignition system is driven off of the cam, and IF, you have a problem with the Dizzy, it requires a water pump removal, and a very expensive diizzy replacement. If the engine is cheap, and you have the ability to wire it, well I guess it would be ok. Just not my cup off tea
cparman is offline   Reply With Quote
Old 04-09-2010, 10:00 PM   #5
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
I love the one in my SWB. Go for it.
low'n slow is offline   Reply With Quote
Old 04-11-2010, 10:35 AM   #6
capev86
fuel injection is the way to go with crazy gas prices, and also it will automatically adjust to changes in altitude so you can go on cross country trips!
capev86 is offline   Reply With Quote
Old 04-11-2010, 04:26 PM   #7
Cap'n Hook
Workin to live...
Cap'n Hook's Avatar
Is the '96 vette an auto or 6 speed. If it's 6 speed, it's not an LT1, it's an LT4, 330 horse! Love the LT4's!
Jason
Cap'n Hook is offline   Reply With Quote
Old 04-11-2010, 05:14 PM   #8
Firebirdjones
Funny, I did an LT1/4L60E swap in my wifes jeep. Very easy swap, hands down easier than an LS swap. Oil pan and motor mounts and exhaust are still conventional style so it doesn't complicate things.
Runs pretty decent too, 13.40's at 103 mph on 32" bfg all terrains and 6 inches of lift
Keeping the fuel injection is cake too. I used Howell Engine Management systems for mine. They supply the computer with a custom tune specifically for the application, and a custom made harness also specifically made for what you are doing. Everything is labeled. Literally plug and play. Fired right up on the first hit of the key.
Nothing really wrong with LT motor's, just have to know your way around them. You don't have to keep the opti either. There are several kits on the market to convert them several ways, even coil-per-ignition setups. If you wish for a carb, you can even switch it over to a conventional distributor if you like. All the provisions are already there, and a plug is made for the front timing cover once the opti is removed. Really makes the engine just as simple as any Gen 1 sbc.
Wouldn't know it by looking at it, a real sleeper.
Firebirdjones is offline   Reply With Quote
Old 04-11-2010, 11:19 PM   #9
Yukon Jack
Post Whore
Yukon Jack's Avatar
Nice Jeep and gotta like that powerplant!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-11-2010, 11:20 PM   #10
71jimmy
71jimmy's Avatar
Sweet conversion.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 04-12-2010, 12:23 PM   #11
Firebirdjones
Thanks, I know it's a blazer site, but I couldn't resist when questions popped up on an LT1 swap
That was a frame off job that took a while and spent way too much money. There was a ton of custom stuff I fabbed throughout the scrambler,,,,but the drivetrain conversion is straight forward and very simple.
Unlike the LS swap I'm gearing up for on our 72 blazer. That's going to be rather involved and quite honestly, I'm mentally preparing myself for it to be a pain.
Old 04-12-2010, 01:34 PM   #12
JMac11
JMac11's Avatar
Would love more details on the Scrambler..... mid LT1 here need inspiration
JMac11 is offline   Reply With Quote
Old 04-12-2010, 03:50 PM   #13
Firebirdjones
I'd probably get booted from the site talking about jeeps I'm into everything though.
I've got a complete photo album from the build start to finish. We did a candy brandywine paint with ghost flames on the hood. Rebuilt the LT1 but it's internally stock, just .030 over. 4L60E with a dana 300 transfer case and 4.10 gears.
If you have an email I can send you pics and details that way, rather than clog up the blazer site with, dare I say it, Jeep info??
