Cab mounts
So im in the need of some Cab mounts. I am either thinking of LMC with their Poly mount kit, only because its cheaper then the O.E Black rubber kit. Although I did see that Brothers has the O.E rubber kit for a Very good price. Not sure which way to go. I need the Rad. Core mounts too.
SO Poly or O.E ?? |
DON'T TREAD ON ME
![]() Join Date: May 2005
Re: Cab mounts
Definitely poly IMO. They don't ride any different than the worn out OE mounts I replaced and they tightened up the body roll and flex a lot.
Old Yeller |
Re: Cab mounts
Here's a link to a thread I saved with some good discussion on poly mounts vs rubber:
Polyurethane Experiences .
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
DON'T TREAD ON ME
Re: Cab mounts
Regarding the squeaking poly mounts, mine are Energy Suspension and they have zero squeak.
Old Yeller |
Re: Cab mounts
We also sell the Energy Suspension mounts. They do not come with the bolts for the cab or rad support bushings though so you would have to make a visit to the hardware store to get them.
http://www.sokyclassics.com/section.php?skcid=1001713 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Re: Cab mounts
Poly mounts do not have any give in them and your chassis flexes a lot. Use poly mounts and your cab will flex right along with the chassis. We have had 3 trucks come in here that have had dammage done to the cab because of the poly mounts. I would do what you want, but my advise is don't use them. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Re: Cab mounts
I would not use Poly on body mounts. The frame is meant to be part of the suspension system and is meant to flex. That is why it is tempered like a spring. If you use poly instead of rubber on the body mounts you are defeating the vibration isolation and the flex that the rubber mounts are meant to provide. On the other hand, if your vehicle is part of a circle track racing circuit, then by all means use poly.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
