Old 04-08-2010, 11:56 AM   #1
1956cameo
1956cameo's Avatar
Van tilt Vs. Truck tilt
I thought that I knew how to tell the difference between a van tilt column and a genuine 67-72 truck tilt column but I am now not sure. Can anyone out there tell me what the differences were between a van tilt and a truck tilt? Thanks!
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 04-08-2010, 12:05 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Van tilt Vs. Truck tilt
Van tilts have about 4" of the column shaft sticking out of the bottom of the column. The truck tilt has 1 1/2" or there abouts. Also the nutral safety switch on a van column is up about 3/4 way to the top and the truck's is near the bottom where it passes through the cab. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 04-08-2010, 02:58 PM   #3
1956cameo
1956cameo's Avatar
Thanks for the info. classic heartbeat! That is what I thought. Does anyone know what all modifications need to be made to put a van column into a truck?
Old 04-08-2010, 03:05 PM   #4
my67chevytruck
Under Construction
my67chevytruck's Avatar
I have heard to collapse the steering shaft by drilling the two plastic inserts, and then moving the neutral safety switch. there is a FAQ. I will see if i can locate it.
**** EDIT *** here is a link:
http://67-72chevytrucks.com/vboard/s...d.php?t=147927
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 04-08-2010, 04:34 PM   #5
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
heres the link..it not a big deal to do it I just did it take about an hour or so...maybe a bit longer if yu have power brakes because you have to remove the bolts on the fire wall and work around the booster....if you don't have power brakes thats another great add tat takes about an hour
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 04-08-2010, 05:17 PM   #6
Slick67
Sofa King Crazy!!
Slick67's Avatar
Here is a pic and a little write-up.
VANTRUCK.pdf
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 04-16-2010, 06:03 PM   #7
1956cameo
1956cameo's Avatar
Thanks everyone! Been off the board for a while but glad to see more info. on this.
