Old 04-08-2010, 12:00 PM   #1
bobshotrodblazer
BigBlockBobby
front axle swap?
I want to swap my 1969 front stock dana drum brake axle for a disc brake set up. How late can I go and still fit......... 85??
Bob
bobshotrodblazer is offline   Reply With Quote
Old 04-08-2010, 05:07 PM   #2
SeventyOne
Re: front axle swap?
I believe '91 is your cutoff. Correct me If I am wrong but this is the last year of the K5 and subsequently the last year of a solid front axle.
SeventyOne is offline   Reply With Quote
Old 04-08-2010, 05:09 PM   #3
msgross
msgross's Avatar
any chevy solid front axle will work... dana44 or 10-bolt... Do you have power steering? Might as well look into that upgrade as well then while you're at it...
I have an 82 corp 10-bolt on my 68 now...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-08-2010, 06:00 PM   #4
bobshotrodblazer
BigBlockBobby
Thanks guys,I have power steering. I'm sure there will be brake hose and master cylinder issues.
Bob
Old 04-08-2010, 07:50 PM   #5
msgross
msgross's Avatar
New brake hoses to match the year of your axle (they went metric on the calipers at some point) and a master with proportioning valve...
The Garage:
Old 04-09-2010, 07:08 PM   #6
Mike C
Mike C's Avatar
88-91 MIGHT have metric lugs. Don't remember for sure, but they changed to 14mm on the redesigned trucks and may have changed the others as well.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
