gas all over the ground in front of my truck
ok so one of the outlets on my fuel sending unit was loose and leaking so i jb welded it and put my bed back on then last night my truck was running really bad like it wasnt getting gas then today im at work i go out to my truck to go to lunch and there is gas everywhere coming from this canister on my radiator support it has the line from the tank one from the intake manifold for vacuum and one blocked off its pulling gas from the tank and drianing it what do i do???
Re: gas all over the ground in front of my truck
i think its just a malfunctioning vapor canister
its called siphoning
ok so i capped the vac port on my intake and the tube from the tank and removed the canister truck runs good now but should i replace the canister?
I would keep it either way, if you need to go for emissions, you could get hit
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
Chevys Kick A$$
Ya x2 I don't know if you emissions or not out there!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
no we dont have emission inspections here
