Old 04-08-2010, 05:15 PM   #1
MT300RUM
MT300RUM's Avatar
Hard shifting 205
What would cause a 205 to feel like it was stuck in frozen peanut butter? feels like i'm gonna snap the shifter off,, Any thoughts??
MT300RUM is offline   Reply With Quote
Old 04-09-2010, 12:22 AM   #2
NorCalTank
Re: Hard shifting 205
Have you checked all the linkage for binding underneath the truck?
NorCalTank is offline   Reply With Quote
Old 04-09-2010, 02:17 PM   #3
SeventyOne
Are you trying to shift while moving? On pavement? Hubs locked?
SeventyOne is offline   Reply With Quote
Old 04-09-2010, 03:57 PM   #4
MT300RUM
MT300RUM's Avatar
Talking Re: Hard shifting 205
Yeah i'm trying to shift it while i'm locked in on pavment spinning cookies while red lined, Why is that bad or improper transfercase shiftting procedere?
No i'm obviously kidding around, And it doesn't matter where you are or what surface your on, there is absolutely zero play or movement in the stick,
it shifts and works properly it just takes about 100 lbs of pressure to move the stick..
Old 04-09-2010, 07:25 PM   #5
SeventyOne
...fluid in the case?
Old 04-11-2010, 04:30 PM   #6
Cap'n Hook
Workin to live...
Cap'n Hook's Avatar
What is the proper procedure for engaging 4 wheel drive with 350/350/205 combo? Do you lock the hubs first then shift? Mine too seems to be really hard to shift between 2 and 4 wheel drive!
Jason
Cap'n Hook is offline   Reply With Quote
Old 04-11-2010, 07:43 PM   #7
Musclerodz
how often do you change gears? The fresh one we just did is a little stiff the first time you move it, but after that would free up. It is the seals that are cuasing it to be that way on ours.
Mike Redpath
Musclerodz is offline   Reply With Quote
