Column swap?????
I am in the process in swapping in a 72 column into my 65 chevy and I am wondering if theres someone that has takin the guess work out of it that can enlighten me on what they did to mount theirs.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
![]() Join Date: Aug 2009
Re: Column swap?????
on my 62 I made a new strap that bolts the column forward to two other dash bolts and allows the mounting for the e brake to be removed without messing with the column, the ts wiring was different on my 62 , the colors matched but they used different positions for the colors so I had to trace back each wire, I used the stock 71-72 rag joint and just collapsed the column to get the length right
Thats kind of what I was thinking in making new straps just was wondering about Ideas on where to start. Thanks Ill post some pics in my build when I think of something.
Take a look here: http://67-72chevytrucks.com/vboard/s...d.php?t=291299
There are several links to posts on this subject. I could not find a column swap info in the 60 -66 FAQ. I couldn't find a section in the 67-72. In one of the posts, Tx firefighter says in put in an FAQ?
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
