Old 04-09-2010, 12:11 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Cooling issues
Info: 85, 305 w/performer intake, holley 600 carb, accel hei with accel super coil, accel plug wires, headers and flowmasters, 350 trans with an above stock stall. Finally fixed the fuel delivery problem and I maintain a constant 5-6 psi, no more, no less. Truck drives and rides great with one exception.
Problem: I drove the truck a short distance and it starts to overheat once it gets up to operating temp. I replaced the water pump and the same problem is there. How can I check the radiator? What do I need to look at so I can fix this problem.
It feels so good to finally drive the truck, so please help me fix this!!!
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 04-09-2010, 12:24 AM   #2
country29
Re: Cooling issues
ck the thermostat or just put a new 1 in it, if that doesnt fix it, take regular granule cascade and water and flush the cooling system, but if you have a blow gun make sure air is passing through the rad and make sure the fan is working this would be where i would start first before you start throwing parts at it or flush the rad. hope this helps.
country29 is offline   Reply With Quote
Old 04-09-2010, 12:26 AM   #3
82chevy350
82chevy350's Avatar
Re: Cooling issues
is it losing any water?
Drive It Like Ya Stole It
'82 Primer White c10 2wd LWB 350 sbc t350
(Hot Rod)
'90 2wd LWB Silverado 350 tbi 700R4
(Daily Driver)
'53 m38a1 Willys Jeep
(Toy)
82chevy350 is offline   Reply With Quote
Old 04-09-2010, 12:52 AM   #4
bitchin85
bitchin85's Avatar
Re: Cooling issues
exact same thing happened to me, it ended up being an air pocket in my coolant. be sure to completly burp the system after you hook all your hoses back up. just fill it with water, leave the cap off, and let it idle. the temp will raise a litlle and the level of the coolant will come up, and start overflowing. just let it keep idleing and spilling out till a bunch of air rushes out and the level goes down. this may take a couple minits. then very slowly top back off your coolant. if need be, do it again. i had to do this to mine twice before i got all the air out. it will seem like its just going to keep spilling and spilling, but let it go. when the air rushes out, you will know it and the coolant level will drop a few inches.
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 04-09-2010, 01:14 AM   #5
RuralRoute C-30
RuralRoute C-30's Avatar
Re: Cooling issues
Went through this topic myself recently. Drove me nuts for a week! Replaced everything but the water pump!
Here is the link:
http://67-72chevytrucks.com/vboard/s....php?p=3878620
Been running perfect and indicates on the guage everything works properly since I replaced the gauge with a mechanical aftermarket one.
Also purchased an infrared thermometer, Harbor Freight was $30, Advanced Auto had them on sale for $60...it would have saved me a lot of time and grief if I had just done that in the first place. A good diagnostic tool to have around.
Good Luck,
Mark
1985 Chevy C-30 Hydraulic Dump Bed
2001 Saturn SC2 (go to work car)
2010 PT Cruiser (wife's car)
"Reality is just a hallucination brought on by lack of alcohol."
RuralRoute C-30 is offline   Reply With Quote
Old 04-09-2010, 11:03 AM   #6
James McClure
One shot, one kill.
Re: Cooling issues
Does it have AC? Not that this in and of itself is a problem, BUT, the space between the rad and condensor is. I had a truck do this and went thru all the tests and checks and couldn't find a problem. Finally, I decided to pull the rad for a flush and the front of the rad was covered with what looked like a carpet made of leafe debris and pine needles. Cleaned all this out and viola, it ran cool. Just a thought, Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 04-09-2010, 05:16 PM   #7
softballnrd27
Re: Cooling issues
I did the whole air bubble thing and took it for a short ride and all seemed in good order. I am taking my son to practice and i will see how it does. Would the lack of a fan shroud cause this problem to happen?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 04-09-2010, 05:50 PM   #8
S10Fan
Old Heap Driver
Re: Cooling issues
Originally Posted by softballnrd27 View Post
would the lack of a fan shroud cause this problem to happen?
yes!
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 04-10-2010, 12:28 AM   #9
softballnrd27
Re: Cooling issues
I let the truck sit in the driveway for at least 15-20 mins idiling and the temp never got above 180-185, and then driving, it begins to overheat. I never thought about the shroud until I read another post. I am going to the junkyard on Sunday to see what I can get.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 04-11-2010, 10:15 PM   #10
softballnrd27
Re: Cooling issues
Well, I got it fixed. It runs great and never gets above 200-205*. I am super excitied and can't wait to drive it to work for the 1st time since I got it and show it off!!!!
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
