Old 02-07-2003, 04:26 PM   #1
jddowell
edelbrock rejet job????
I have a Edelbrock 1406 carb. on my old 72 that I want to rejet a little leaner. I ordered new jets "#1426-.095, new rods"#1456, and a set of different springs. According to the chart I will be leaning down to the #7 position. My question is how hard of a job is this? According to the manual it is suppose to be a simple job but, I would like input from ordinary people who have done it, and their opion as to what I should be aware of before I start.
jddowell is offline   Reply With Quote
Old 02-07-2003, 04:36 PM   #2
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
jddowell
Mess with mine quite a bit the metering rods and springs are a piece of cake ,takes about 5 min. once you do it a few times.
You don't have to take the carb off to change the jet's but I always do it's a lot more convient .
I assume you are changing the primary jet's ?as the secondary's are already .095 .
I also check the needle and seat and float level when I have the carb off.
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 02-07-2003, 04:44 PM   #3
crazy longhorn
Fabricate till you "puke"
you might check the float levels before you start jetting......my 1407 had a float too high(bounced around in shipping Im sure), & it ran very rich. I did also lean the cruise mode a tad.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-07-2003, 05:34 PM   #4
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
I want to get more power/performance out of my 1406. What jet sizes should I go with? I just have the ones that came with the carb. Thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 02-07-2003, 06:36 PM   #5
crazy longhorn
Hotrod, every combo tunes a little different. Best bet is to go into edelbrock's site ...... http://www.edelbrock.com/ , & look under carbs/ tuning tips. Im a beleiver in "read/learn all you can about the equip you are dealing with", then go to town. Good luck.....crazyL
Old 02-07-2003, 06:58 PM   #6
Bill72BB
Bill72BB's Avatar
HotRod929 ; I agree with Crazy Longhorn , I'll bet you are probably missing the massive amount of fuel the Q-jet dumped when you hit the secondarie's . if so my first suggestion would be to go to a larger secondary jet's ,the 1406 came with .095 , so you may want to go to a .o98 or .101 .for starters
BILL
Member DUF Club
Old 02-07-2003, 07:18 PM   #7
crazy longhorn
Bill nailed that square on, the Q jet had a bigger "seat of the pants" feel when those big seconds crashed open. I think the squarebore carbs have a little more across the band, but you will also pay for a little more "motion lotion"....the spreadbore are more economical........crazyL
Old 02-07-2003, 07:22 PM   #8
HotRod929
HotRod929's Avatar
Bill72BB - Which ones would you recomend trying first? I really do miss the feel when the secondaries on the Q-jet opened up.
I dont mind fuel economy much just want that feal back again!
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 02-07-2003, 07:30 PM   #9
Bill72BB
Bill72BB's Avatar
HotRod929
I tried a couple and settled on the .101 ,that is what I've been running in the secondaries .
BILL
Member DUF Club
Old 02-07-2003, 07:42 PM   #10
HotRod929
HotRod929's Avatar
How bout the primaries...you think they could go bigger?
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 02-07-2003, 08:30 PM   #11
Bill72BB
Bill72BB's Avatar
They are .098 stock ,I never tried a larger jet but I tried a few different Metering rods ,to help richen up at idle and cruising speed ,just went back to the stock one's to try to help gas milage.The one's I took out were 73/42 ,but I,m running a BB .
BILL
Member DUF Club
