Old 04-09-2010, 12:28 PM   #1
masaki
This chevy truck axle is a good replace for my blazer rear axle?
Hi, I have a 1973 GMC Jimmy 4x4 for a restore project, but, the rear axle is not the original, (the old owner replaced the axle with another model with 5 nuts in the wheel) now I want to replace this with another axle, because I want to activate the 4x4 option in the blazer, after some search here, I found a chevrolet truck, it's for sale, I want to know if I can use the rear axle, I want to know if this axle is the same model of the blazer o GMC jimmy 1973
here is the truck... (all I know is: this is a 69 truck, 2WD, L6 250 engine, suspension: front coils rear leaf)
1988 Ford taurus LX SW
V6 3.0L vulcan - Axod
1973 GMC Jimmy Sierra 4x4
L6 diesel nissan LD28 (temporal engine)
masaki is offline   Reply With Quote
Old 04-09-2010, 12:37 PM   #2
rwolf9653
more ideas than money
rwolf9653's Avatar
Re: This chevy truck axle is a good replace for my blazer rear axle?
It is hard to tell from the pictures, but I think it will swap over. As long as it is going leaf spring to leaf spring you may need to move the spring perches.
Please remember that you need to make the gears match front/back, otherwise bad things happen!
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 04-09-2010, 01:27 PM   #3
Burt4x4
Burt4x4's Avatar
Are you trying to go from "5 nuts" to "6 nuts"?
I think that green 2x4 might be a 5 Nutter?
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-09-2010, 01:34 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea x2 that's exactly what I was thinking. Need to find a 4x4 with the 6lug set up! Don't forget to match the gears like stated above.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-09-2010, 04:31 PM   #5
masaki
my GMC original axle is 6 nuts (4wd) this chevy truck have 6 nuts but is 2wd
