Old 04-09-2010, 06:01 PM   #1
zerotoredline
keeping 3 on the tree
i am keeping the three on the tree and i was wondering what other motors besides my inline 6 will bolt to that tranny...
zerotoredline is offline   Reply With Quote
Old 04-09-2010, 06:05 PM   #2
Re: keeping 3 on the tree
Any small block Chevy V8, GM V6 and may even work behind a Big block.
To keep the stock shift linkage you'll need a different Z-bar.
Old 04-09-2010, 06:11 PM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Yep, like Palf70Step says, they will all bolt up. Even to the BB. The bellcranks are different for the different motors though. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 04-09-2010, 07:40 PM   #4
zerotoredline
so i need a different bell housing and z bar...? how do i find out what z bar do i need?
i like the straight six but i also love the dual exhuast sound and i figure with a good 305 it would be better on gas mileage?
Old 04-09-2010, 09:11 PM   #5
Chevydude56
Chevydude56's Avatar
You can use the same bell housing . It looks like the Z-bar is different for 6 cyl. and small block . I found a listing in car shop truck shop catalog , but i am sure other vendors have them .
http://www.scribd.com/full/17608177?...qy43h7a9pmdutn
You could also try the used parts for sale
1967 Suburban 292 3spd
1964 Chevy II wagon
1971 Monte Carlo 402BB
1964 Cadillac series 62 2dr
1964 Bonneville 2dr/ht
1967 GTO
1978 Chevy Van 30
1989 R30 Crew Dually Bonus Cab
Chevydude56 is offline   Reply With Quote
Old 04-09-2010, 10:36 PM   #6
capev86
on my 74,000 mile 72 burb 3/4 ton 2wd with 307, 3 on the tree, 4.57 rear....
installing a 4.10 third member into the HO52
swapping in a 406sbc
adding the factory borg warner OD unit
putting in a McLeod ceramic clutch at engine swap
the rear gear swap will be done in the next few weeks along with royal purple gear oil, i drained and put in royal purple manual trans fluid in the saginaw and currently working on an 85 q-jet / edelbrock intake swap on the 307 so i can use the truck this summer for towing the family's 6000 pound '71 holiday trav'ler 23 footer that has been in the family almost since my dad got his first suburban (a 72 1/2 ton) in 1983. if this had been a floor shift truck, i would have ripped out the trans and put in an aftermarket modded late model 6 speed w/ a mechanical clutch conversion and features overdrive ratios in 5th and 6th gear with a lower first ratio than the saginaw. but i do like having a column shifter with a bench seat, but getting to drive a stick trans. just wish 3rd gear didn't come into play at 25mph!
capev86 is offline   Reply With Quote
