Little A/C Help, please.
I've got an Old Air 7200 Hurricane unit on my '69. It's been operating flawlessly for the last seven years. Yesterday it was going along fine and the compressor just quit- the fan operates fine. I can't seem to locate the problem. Here's what I've done so far:
* Static pressure is 65 psi at 70 F, both sides- enough to close low-pressure switch, right? * tested dash switch with test light (light on) and then jumped termial plug (no compressor) * tested evaporator thermostat terminals with test light- light came on * Jumped low-pressure switch plug- no compressor. By passed plug entirely and connected wires - no compressor. * tested reley- a 5 pin. It clicks when dash switch is engaged. With mulit-meter, no power pins 85 & 86 pulled 89 ohms; 30 & 87 0. With power; B+ to 85 & B- to 86, heard a click ; 30 & 87a 0; 30 & 87- 9. I think that's OK. * All fuses & wires look good. Did I make any errors or what should I be doing next? Thanks!
![]() ![]() Last edited by Zonaman; 04-09-2010 at 07:23 PM. Reason: error |
Re: Little A/C Help, please.
ohm the cluch on the compressor or just wire it to the batt and that should tell you if the cluch is bad
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
#3 | |
Thank you.
![]() ![]() Last edited by Zonaman; 04-09-2010 at 08:13 PM. |
Connect ohm meter to power wire and to ground/case of compressor.
Have you checked for 12V to the compressor clutch with the system turned on?
1967 Suburban 292 3spd 1964 Chevy II wagon 1971 Monte Carlo 402BB 1964 Cadillac series 62 2dr 1964 Bonneville 2dr/ht 1967 GTO 1978 Chevy Van 30 1989 R30 Crew Dually Bonus Cab |
![]() Join Date: Jul 2003
^ What he said, jump power to the compressor clutch. See if it turns on, if it does work your way back.
Pull the wire off the clutch. Measure ohms from the connector to ground.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Sanden compressors coils have a pretty high failure rate especially if the gap is not correct, if it has power to the compressor try to tap the clutch with a hammer handle while powered up to see if the coil can pull the clutch in.
#8 | |
How many ohms should I see? Does it matter if the system is on? Thanks guys, this is a great help!
