Old 04-09-2010, 09:28 PM   #1
WestButteTruck
Kung Fu Master
WestButteTruck's Avatar
Used Demon 650 carb
I have a used Demon 650 with vacuum secondaries that will need a rebuild. I took it off a running 84 with a 350 but I'm not sure the secondaries were working. Electric choke, however it would stick from time to time. Had it hooked to a 700R4 but I'm not sure the linkage was correct. At any rate, I ran it for over a year until I replaced with an edelbrock. AS IS $100 plus the ride. No PM's. I will try and do my best to answer any questions.
SOLD pending payment to FOREVER71, thanks
72 GMC SuperCustom 4x4
1972 Chevrolet Cheyenne Super 4x4
WestButteTruck is offline   Reply With Quote
Old 04-09-2010, 09:43 PM   #2
darthwall
Re: Used Demon 650 carb
If that was a manual secondary I would have bought this right now good deal
darthwall is offline   Reply With Quote
Old 04-09-2010, 10:31 PM   #3
FOREVER71
FOREVER71's Avatar
ill take it pending a part# to verify its a 650 and shipping to 97080...thanks
FOREVER71 is offline   Reply With Quote
Old 04-09-2010, 10:45 PM   #4
BarryB
BarryB's Avatar
If forever 71 passes, would you be interested in a trade? PM me if so, because I tend to forget where I post stuff. I have a carter AFB 750 , same as an Edelbrock. I also have several other pieces and parts you might be interested in.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 04-09-2010, 11:07 PM   #5
WestButteTruck
Kung Fu Master
I had to use the Barry Grant website and input some numbers.
http://www.barrygrant.com/demon/imag...tity-Speed.pdf
I have a 6 cast into the top of the body and also the "downleg boosters" which comes out to the 650, VS on the side for vacuum secondary. There wasn't a part number on it anywhere else I could see. I spent some time a while back researching this and am pretty confident in my findings.
FOREVER71, let me know if you are still interested. Is USPO o.k. for shipping?
Old 04-09-2010, 11:55 PM   #6
FOREVER71
FOREVER71's Avatar
postal is fine...could ya get me a pic of front , back and underside?...thanks...jeremy
Old 04-10-2010, 12:10 AM   #7
WestButteTruck
Kung Fu Master
pics
Old 04-10-2010, 05:12 PM   #8
FOREVER71
FOREVER71's Avatar
hey, its weird that all the numbers arent there. im not sure about buying it due to the fact that i bought a 500cfm off ebay already,that was supposed to be a 650cfm. thats why i need the numbers. i dont want to buy a rebuild kit and find out it wont work fo one reason or another.....jeremy
Old 04-10-2010, 09:28 PM   #9
WestButteTruck
Kung Fu Master
Did you check out the web address I posted above? Mine has the number "6" cast into the body, and it has the downleg boosters. Plug in the numbers, you get the 650. I'm convinced. I guarantee or your money back. There, it's in writing. If you don't want it let me know so I can move on to the next person.
EDIT: SOLD to FOREVER71, thanks
Old 04-10-2010, 09:58 PM   #10
FOREVER71
FOREVER71's Avatar
whats shipping?...pm me your address...ill get ya a money order...jeremy
Old 04-11-2010, 01:23 AM   #11
hotrod 80
mini truck racer
hotrod 80's Avatar
Put me in line . If it has a 6 on the air horn and down leg boosters . Should fit nicely in a Large flat rate box .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
