04-09-2010, 09:57 PM | #1 |
computer illiterate
thorley headers
i just put a set on my 1972 2wd blazer with a 5.3/4l60e and the driver side header runs directly through the factory shifter linkage? i used the ece mounts that i believe they where designed around. i thought these where made to fit these trucks? i have an awful lot of money in these for this result. anyone else have this problem?
72 2wd blazer 72 swb 4x4 |
04-09-2010, 10:08 PM | #2 |
Re: thorley headers
You'll need to use a Lokar or Kugel shift linkage. Either works great.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-09-2010, 10:18 PM | #3 |
computer illiterate
Re: thorley headers
got a link to said linkage? in all the posts i read about these headers i must have missed that about the linkage. i probably wouldnt have used them if i had known that. they are very nice headers though.
04-09-2010, 10:20 PM | #4 |
Re: thorley headers
http://www.summitracing.com/parts/LOK-ACA-1800/
You'll like it. Very adjustable and way better than the original setup.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 04-09-2010 at 10:21 PM. |
04-09-2010, 11:22 PM | #5 |
Re: thorley headers
I have the same headers and the same lokar linkage works like a champ....if you look by the master cilynder you can see a glimpse of it.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
04-10-2010, 12:36 AM | #6 |
Truck and auto performance nut
Re: thorley headers
I don't know....but I'm thinking maybe your sbc is a little different then his 5.3L?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
04-11-2010, 12:54 AM | #7 |
Re: thorley headers
LOL maybe just a little
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG) |
04-11-2010, 01:04 AM | #8 |
Re: thorley headers
Do they really sit that high up above tranny pan? Sweet...
04-11-2010, 01:12 AM | #9 |
Re: thorley headers
Real sweet.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 04-11-2010 at 01:13 AM. |
04-11-2010, 01:17 AM | #10 |
Re: thorley headers
Rob, That is 324Y correct? Is that your suburban?
04-11-2010, 01:25 AM | #11 |
Re: thorley headers
That's correct.
04-11-2010, 09:27 AM | #12 |
computer illiterate
Re: thorley headers
oh yeah they fit great. i just wasnt expecting the shift linkage to be affected as i hadnt read that before. thats why i started this thread so if someone was buying them they would know what to expect. i havent figured out which shift linkage to go with yet.
04-11-2010, 10:03 AM | #13 | |
Re: thorley headers
We sell the lokar linkage for $46.00 in stock ships tomorrow We are less than Jegs or Summit on most all parts with a better parts purchase policy |
04-11-2010, 10:42 AM | #14 |
computer illiterate
Re: thorley headers
is that what i need to use my column shift with the 4l60e? got a part number? is that shipped?
04-11-2010, 10:44 AM | #15 | |
Re: thorley headers
04-11-2010, 10:44 AM | #16 |
computer illiterate
Re: thorley headers
anyone have a pic of this lokar linkage installed with the headers? Rob?
04-11-2010, 10:45 AM | #17 |
computer illiterate
Re: thorley headers
i did click the link the other day i am just wanting some installed pics? not quite seeing how this would be much different then the stock linkage.
04-11-2010, 10:45 AM | #18 |
Re: thorley headers
Not yet. I should be hooking that up some time this week and then I will post some pictures.
04-11-2010, 10:49 AM | #19 |
computer illiterate
Re: thorley headers
cool thanks. i want to hear some feedback on it before i buy.
04-11-2010, 10:50 AM | #20 | |
Re: thorley headers
Here's a picture from Lokar's website: http://www.lokar.com/interior_pages/...lshiftlink.jpg
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 04-11-2010 at 10:51 AM. |
04-11-2010, 10:57 AM | #21 |
computer illiterate
Re: thorley headers
lol..... about the part number. i went to there website and checked it out that looks like it will work. if not the cable one will. i really dont like cable shifters though.
04-11-2010, 11:12 AM | #22 | |
Re: thorley headers
Our shipping is $13.00 plus never a handling charge,restocking fee or any fee of any sort.Plus you have two year full refund on all parts if not used exact shipping cost to if less we refund the difference |
04-11-2010, 01:30 PM | #23 |
computer illiterate
Re: thorley headers
wow sounds good mike. when hart rod installs his and i can see the pic ill get one from you.
04-11-2010, 02:26 PM | #24 |
Re: thorley headers
I really like these headers and how tight they are to the frame, I just wish these were available with larger primaries. 1 5/8" might be ok for the smaller LS1's or even the LS2's with the cathedral port heads...but the 6.0's and 6.2's with the large rectangular port/larger valve heads need a little more...like 1 7/8" or at least 1 3/4", with a 3" collector.
04-11-2010, 02:41 PM | #25 |
Re: thorley headers
Thats what I was thinking 68GMCustom, I'll be running a 6.2 and I want it to flow. I wanted to run dual 3" out to the rt side front rear tire. I'm wondering if it will be counterproductive to run the dual 3's if I'll be choking down at the primaries and collector. Love the Thorleys though.
