73 chevy coil wire color
could anyone tell me the color of the positive and negative ignition coil wires.
someone switch mine to hei before i got it. now i need to find the negative wire that went on the coil so i can put a igintion box on it.
72 SIERRA LB 74 C10 SB 85 C10 SB 75 EL CAMINO SS ![]() |
The One And Only !!!
Re: 73 chevy coil wire color
There was no negative coil wire in the harness, A wire ran from the negative coil post to the points in the distributor. The old (should be red) positive wire that now goes to the BATT post on the HEI cap will go to the positive post on the old style coil (switched power).
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
