04-10-2010, 01:16 PM | #1 |
Hei
When putting in a hei distributor what needs to be changed in order for the engine to work? My truck is a 66 with a 283 in it now, soon to be a tweaked 350. I heard something about using heavier gauge wire and a starter button. Is any of that right? Thanks guys!
04-10-2010, 03:54 PM | #2 | |
Re: Hei
1964 Chevy C10 a.k.a. Julie Ann H.E.I. cause its better to be pointless |
04-10-2010, 08:38 PM | #3 |
Re: Hei
Thanks for the reply so that extra stuff isn't really needed after all.
04-10-2010, 09:09 PM | #4 |
Hey Watch this...
Re: Hei
When I put in the HEI on my 283, I was amazed that it was that simple. Best money spent on the truck yet.
What have I gotten myself into now? 1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress 2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids |
04-10-2010, 09:47 PM | #5 |
Re: Hei
drop it in ,give it a 12 volt power supply (switch on ) and you will be fine.its also a great improvement over points.
04-10-2010, 10:56 PM | #6 | |
HOW long until spring??
Re: Hei
My 69 chevelle and my 71 El Camino both had a resister wire between the key and the points distributor (purple? or pink?) that needed to be replaced with a normal wire when installing a HEI. There was also a wire to remove from the relay side of the starter solenoid. The theory was to provide a full voltage to the distributor while the starter was energized (for starting ease) then drop the voltage slightly to prolong the life of the points while running. The diagram for my 64 truck does not show any such resister wire in the harness Post some pictures when you get a chance. we like pictures Check out the Idaho club here, we have a few local guys. User CP in top header>Networking in left header>social groups >Idaho club
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
04-11-2010, 12:33 AM | #7 |
60-66 Nut
Re: Hei
When I've converted to an HEI, I eliminate the original wire from the switch to the coil. Then replace it with a 12ga wire from the switch directly to the HEI. Just make sure you are getting a full 12+ volts to the distributor. And as Bubba327 said, remove the wire from the starter solenoid to the coil.
04-11-2010, 12:40 AM | #8 | |
Re: Hei
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) |
04-11-2010, 06:07 PM | #9 |
Re: Hei
Thanks for the welcome Bubba327 I will check out the the Idaho club for sure. Sounds like I have a little bit wiring to do. I havn't gotten a manual for the 66, do you guys recommend any certain one before I start tearing the ol' truck apart. Next week or so I'll be putting in the motor and give it a try on painting the engine bay I'll have some pics to put up.
04-12-2010, 06:12 PM | #10 |
Re: Hei
I just change out my point dist. for an HEI unit, MAN what a differences! IF you look at your solenoid from the rear, the connection on the left side (closest to the frame) has 2 wires, on my 64 one is yellow and the other has a braided covering (this is the resistance wire) when you cut into it this has a steel wire. When cranking to start the motor the 12 volts is sent to the dist., but once it has started the voltage is kicked down to 9 volts so it doesn't burn up the points. But on a HEI unit it needs 12 volts all the time so you need to cut out the resistor wire and replace with 12 or 14 ga. wire 16 ga would probably work too ...you are only carrying 12 volts.
Big different in performance!! With half the hassle on a tune-up! Good Luck! |
04-12-2010, 10:07 PM | #11 |
Re: Hei
FYI its the amps or current flow that dictate the size of wire needed, not voltage.
just look at the size of the wiring in your house....... |
04-13-2010, 10:41 AM | #12 |
Re: Hei
trevota Re: Hei
FYI its the amps or current flow that dictate the size of wire needed, not voltage. Just look at the size of the wiring in your house. trevota is quite right AMPs do dictate wire size. All I was trying to indicate is that it's only a 16 or 18 ga wire that carries the 9 or 12 volts to the distributor now so that size could be used again in the HEI up-grade. ...My $0.02. |
