Old 04-10-2010, 05:28 PM   #1
molinehotrod
molinehotrod's Avatar
Post pics of lowest spring set-up
Drop springs front and rear, and lots of modifications
molinehotrod is offline   Reply With Quote
Old 04-10-2010, 06:40 PM   #2
Slmd92DIME
Slmd92DIME's Avatar
Re: Post pics of lowest spring set-up
That looks really good man. I like it a lot
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 04-10-2010, 09:38 PM   #3
Mike J
vw guy & now c-10 guy
Mike J's Avatar
that does look really good.
post up some specs brother, I'd like to know what you've done.
I have a 5.5/7 static drop but it sure doesn't look like that! lol
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 04-11-2010, 12:26 AM   #4
jimmy1614
Exactly what im tryin to do with my 81 and a static drop. May we see more pics and some more info on the front end mods please? Thanks!
jimmy1614 is offline   Reply With Quote
Old 04-11-2010, 10:36 AM   #5
molinehotrod
guys i've got drop spindals,drop springs that i cut a coil off, then i moved the cross member up in the rails 2 inches, notched front rail for steering to clear, moved shock mounts,new motor mounts, new trans cross member, new trailing arm cross member, new rear shock mount cross member, z'd rear frame 4 1/2 inches and you cant tell, when i z'd the frame i did it vey tasfully, you can look at it not tell that it is z'd, i have 4 inch drop blocks and drop springs. The front i had to narrow the front a arms 1 1/2 inches so that i could turn. I work at a rod shop and we had a customer that wanted air ride, so we got him the rear air bar kit and front a-arms and bags with drop spindals, and all the digital controls, i think the kit was like 6500 from air ride, well he was upset that he was aired out and i was two inches lower than him. I've got about 200 in steel to get the frame down. i already had all the springs and spindals.
Old 04-11-2010, 11:29 AM   #6
nlped
nlped's Avatar
Wow, that does look cool!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-11-2010, 11:39 AM   #7
smbrouss70
smbrouss70's Avatar
I'd like to see pictures of your rear Z, if you have some.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 04-11-2010, 12:05 PM   #8
kev2809
low n' slo
kev2809's Avatar
^^ x2
that looks great for being static dropped. its funny your lower than a lot of bagged rides lol. so do you ever plan on bagging it...and how hard is it to drive?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 04-11-2010, 12:51 PM   #9
SCOTI
SCOTI's Avatar
Not knocking your work.... but he wasn't set-up w/the correct air ride kit. If he spent $6500 on Ride Tech products, he got what he paid for (a set-up that's not made to lay out or go much lower than 2-3" beyond stock ride height).
Porterbuilt products would have been a better choice for extreme air-ride drop as would other companies....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-16-2010, 12:41 AM   #10
rustSpot
*NO REGRETS*
rustSpot's Avatar
Dig it! Any updated pics?
rustSpot is offline   Reply With Quote
Old 02-10-2012, 07:59 PM   #11
Red4x4
Update?
Are you even still on here anymore? probably not.
Red4x4 is offline   Reply With Quote
