View Poll Results: Should neck be welded | |||
Fine the way it is |
8 | 20.51% |
It should be welded |
31 | 79.49% |
Voters: 39. You may not vote on this poll |
I would like your opinion of a gas tank I had made!
I had a gas tank made for my LS swap in my Jimmy. The builder says that the filler neck is welded from below.
I agree it is or would fall out. It sure looks like it was prepped for welding and think it would look better finished/welded on top. So whats your opinion? ![]()
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 Last edited by Thealien; 04-10-2010 at 07:16 PM. |
Re: I would like your opinion of a gas tank I had made!
It probably won't matter, but it would look better welded up..
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
looks cleaner that way...imo..
![]() Join Date: Mar 2003
I would either weld it or put some kind of sealer to keep debris out of the seam
![]() Join Date: Apr 2005
JB Weld.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Ahhhh, JB weld. Somebody beat me to it.
Can you back your camera up and show the whole thing?
Shake and Bake!
![]() Join Date: Feb 2010
If you have a good TIG guy near you, I bet they would weld that up cheap. I personally would want it welded up on the top to match the look. It looks kinda unfinished.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" Last edited by Leviticus; 04-10-2010 at 09:20 PM. |
Active Member
If I am a betting man you could not weld 360 degrees around the neck due to the centerline of the neck to the top of the tank
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
![]() Join Date: Jun 2002
I would imagine it would be welded, or it would fall off as already mentioned, but it don't appear to show any heat signs in that area, mig welded?? judging by the surrounding welds, I would leak test the tank before doing any thing (no more than 4 PSI for a rectangle vessel). Look real close for leaks, gas will find ways out when water or air wont. Nothing will piss ya off more than completing the instl, filling it up & seeing & smelling gas.. If no leaks then seal the joint around the filler tube with clear silacone, just to keep water / corrosion out. Once installed, you wont see it anyway
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
What?
I didn't vote on your two choices.
I'm fine with it the way it is, but the nit picker in me would put some sort of bead of sealant around the top to prevent rust.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Active Member
If it is solid I would get some plumbers solder and fill the gap. This way it would prevent rust and fill any pin holes that might be in the weld. Also would still be somewhat flexable and won't chip out like JB weld.
What's the tank made from? I would also like to see pics of the whole tank. Thanks
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin Last edited by Zeke; 04-11-2010 at 07:47 AM. Reason: questions |
#13 |
Here is the top of the tank. I will take pics of the sides, front, and back when I am near the tank. It is at a fabrication/welding shop where I am having my transmission pan notched for driveshaft clearance and he is going to tig weld the fuel filler. Even though it will not be seen and is probably 100% functional I just feel it would be "right" to be welded. It is aluminum and made to my dimensions.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 Last edited by Thealien; 04-11-2010 at 10:07 AM. |
#14 |
computer illiterate
that looks like a fuelcellguy tank? i have one and its fine. i have never heard 1 complaint about any of his tanks so im sure it wouldnt be an issue.
72 2wd blazer 72 swb 4x4 |
#15 |
Well the tank leaked at the very bottom seam
![]() I used JB weld on the seams and it seems to be holding, time will tell. It is a fuel cell guy tank. If I sent the tank to him I am sure he would have fixed it but I didn't want to wait or argue about shipping costs. Right now the tank is holding about 5 gallons and the engine runs!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#16 |
wanna be 67
Would sure like to hear fuel Cell guys response on this. I am thinking of buying a tank soon. A leak on the seam? Seriously? Was it not checked for leaks before it was shipped.
#17 |
In his defense he emailed a response back almost immediately. He says he has never had a leak in ten years and that he pressure tested my tank? He asked if I tweaked the tank or anything. I offered to send him a video showing the tank leaking and that the seam looked welded with no dents, scratches or anything. He replied a video would not be necessary.
He asked what he could do to make it right. I am not sure if he would have paid shipping both ways to fix the tank or not and I did not ask. I really did not want to be without the tank for 2-4 weeks with shipping and everything. I asked him if he thought JB weld would work and he replied yes. It seems to have worked but I only have 4-5 gallons in the tank right now. I have read many, many satisfied customers so I have to assume mine was a fluke? I didn't post about the leak to bash anyone and that is why I have not posted in the review area. I am about as anal an electrician as there is and I occaisionally make a mistake. I guess its possible I am the only leak in ten years. Am I thrilled my new $700+ tank leaks and now has JB weld on one corner, NO But It is what it is. If you wanted to ask him anything I would ask if your tank leaks would you have to ship it back on your dime?
#18 |
Do those tanks have the square baffling in the bottom that keeps the gas centered while turning?
#19 |
On the FI tanks he has two baffles that run from the front to the rear of the tank.
#20 |
cool ,thanks
#21 |
FUEL CELL GURU
I just saw this. I would absolutely have paid the shipping back to me and back to him. I have been doing this for a long time and have never been one to be happy with an unsatisfied customer. I want the tank the fit right the FIRST time with no problems. I will go as far as building a completely new tank if the need ever arises. My main concern is customer satisfaction and ease of installation. I have always stood behind my products. I did a lot of R&D on these tanks to make them affordable and easy to install. When you buy a tank from me, you have nothing to worry about. As far as the filler neck, they are welded from the bottom before the "lid" is welded on. This is a far better method in my opinion for attaching the fill tube. Does it look unfinished? Yes, but I never knew of it to be an issue. I will always welcome any constructive critism. That is what makes things better. Please, if anyone has any questions or concerns about my products, contact me and I will do everything in my power to make I right. Thanks to all my loyal customers. Mark
#22 | |
#16876
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#23 | |
FUEL CELL GURU
That may work.... |
