Lowering the rear of a 2wd truck?
I would like to lower the rear end of a 71 C-10 2" from the existing height. My question is what is the starting height that is used for coil springs when lowering?
In other words will I get 2" lower by using springs that have a 2" drop? Right now the truck has new stock springs in it and it sits up fairly high in the rear. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
![]() ![]() Join Date: Jul 2002
Re: Lowering the rear of a 2wd truck?
Chances are if you have original springs (old) in there now, you'll see less than 2" with the new 2" drop springs. How much depends on how worn the current springs are.
The Older Generation
If you want to keep the "new".. ![]() LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-10-2010 at 09:05 PM. |
Thanks for the replies. I will look at LockDoc's suggestion. It sounds like the way to go.
Jim
#5 | |
Junior Member
I have a '71 with the optional heavy duty springs that I want to lower, but did not want to go with lighter duty springs. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
I was wondering about DIY blocks. I have some left over metal from a notch we did on my buddies mazda. Looks like I found a place for them. Did you do anything to them to stop them from moving? Thanks
Sheetmetal Psycho
I think you run the longer ubolts through the 2" blocks
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
That is correct. If you have coils in the rear you drill holes in the lowering blocks and the "U" bolts go down through them (the blocks go between the rear axle pads and the trailing arms).
LockDoc
