Old 04-10-2010, 09:00 PM   #1
tim21391
tim21391's Avatar
truck cutting out?
its cutting out on highway and i dont know what else to look at.. its got a rebuilt holly carb.. just adjusted the rockers.. did those at 1/4 turn and it seems a whole lot better in town.. like it idles and drives smooths.. sounds good.. but then on highway it wont go past 70... what do i do now?
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-10-2010, 09:01 PM   #2
tim21391
tim21391's Avatar
Re: truck cutting out?
its hei to by the way
Old 04-10-2010, 09:15 PM   #3
Leviticus
Shake and Bake!
Leviticus's Avatar
What type of fuel pump are you running, electric or mechanical? Have you tested your fuel PSI?
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 04-10-2010, 09:18 PM   #4
tim21391
tim21391's Avatar
mechanical and its not even like 3 months old
Old 04-10-2010, 09:19 PM   #5
tim21391
tim21391's Avatar
and no i have not whats all the steps involved
Old 04-10-2010, 09:26 PM   #6
norske
If you mean kind of sputtering and not shutting off completely, I had something similar on my old 440 mopar. At about 70-75 mph it would sputter and pop. Lifted the hood and ran the rpms up in the dark and there was quite a light show. The spark was jumping thru the plug wires to the engine. Re-routed the wires and it was ok.
norske is offline   Reply With Quote
Old 04-10-2010, 10:44 PM   #7
justincat
Yea I would get a fuel pressure gauge and test that first. Could also need different size jets. What is your idle mixture screws set at? I would put new plugs in it, drive it while its cutting out, find a place to shut it off while its running and check the plugs. Check back and tell us what your plugs look like, and that would help alot on whats going on. You cant really test the plugs after its been idling, you need to turn the key off while your driving it. Do you have a timing light, that could also have something to do with it? fuel filter cloged? Sorry so long of a post but theres a few things that could be wrong.
justincat is offline   Reply With Quote
Old 04-11-2010, 01:47 AM   #8
MT71c-10
Too many toys,not enough money
MT71c-10's Avatar
I know you have a few other threads going, I have not read them all. But have you changed the fuel filter with all this going on??
Looking for all Montana members. PM me or send friend request.http://www.67-72chevytrucks.com/vboa...36#post3813336
MT71c-10 is offline   Reply With Quote
Old 04-11-2010, 08:31 AM   #9
Shyguy
Junior Member
Shyguy's Avatar
You might also check for colapsing rubber fuel lines. I just found that the one from the tank to the fuel pump on mine is.
I just put a new one on a couple of weeks ago, but the normal rubber hose now days is crap so I am going with the heavier duty type I use on the power steering suction.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-11-2010, 10:16 PM   #10
tim21391
tim21391's Avatar
new fuel filter and new rubber lines put on back in july but they might be failing like yall said.. ill check the plugs out this weekend and possibly get new ones.. new plugs went in in july but they couldve gone bad since the carb was all screwed up
