Old 04-11-2010, 01:18 AM   #1
68lngbed350
rear end curiosity
Im a little confused, my 68 3/4 ton chevy has a 10 bolt rear end. I was told 3/4 tons never came with 10 bolts, only 12 bolts. Is it possible somewhere along the line that someone replaced the original 12 with a 10 bolt. The trucks been in my fam for over 20 years but before that i know it had a handful of owners. Any helpful input would be appreciated.
1968 C20 Stepside 350 sm465 4.57 - Summer Cruiser/Hauler
1980 El Camino- lil brothers dd. lt1 3.90
1970 Camaro-468 bbc t56 4.11 MONSTER! younger brothers project
68lngbed350 is offline   Reply With Quote
Old 04-11-2010, 05:40 AM   #2
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: rear end curiosity
Does it look like the one below? That's not a "10-bolt" per se. It has a 10 bolt cover, but is commonly called an "Eaton" and is a different class of differential. To my knowledge 10-bolts were not used in 67-72 trucks.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 04-11-2010, 06:19 AM   #3
Blazer1970
Blazer1970's Avatar
Also, no 12 bolt ever came in a 3/4 ton. The 12 bolt is a half ton axle.
Blazer1970 is offline   Reply With Quote
Old 04-11-2010, 10:54 AM   #4
martindc1
Don't dana 60s have 10 bolts on the cover?
Is your axle a full floater with 8 lug wheels?
Currently truckless, previous trucks:
67 K20, 87 K10 aka V10 & 72 C10
martindc1 is offline   Reply With Quote
Old 04-11-2010, 12:37 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
It's actually not the number of bolts that hold the rear cover on that are counted. It's the number of bolts that hold the ring gear on the carrier. It just happens to coincide with the number of rear cover fasteners.
There are some B.O.P. rear ends that have 12 bolts holding the ring to the carrier, and 10 bolts holding the diff cover on.
...and I'm betting that the truck in question has the Eaton in it.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-11-2010, 12:37 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you guys are confusing the term 10 bolt.
The 10 bolt rear is not just any rear with 10 bolts holding the cover on. It is a specific design of rear end that GM used.
The 3/4 tons of this era mostly had the corperate rear, or as we call them on here, the eaton. There were plenty of 3/4 tons 67 - 72 with the dana rear too.
Old 04-11-2010, 07:57 PM   #7
68lngbed350
shaky: yes my rear end is identical to that one pictured.
martindc1: i dont know if its a ff but its definitely an 8 lug
thanks for all the replies fellas. since it seems i have an eaton rear, does anyone know what gear ratio it has?
Old 04-11-2010, 08:08 PM   #8
vectorit
What?
vectorit's Avatar
No way to tell by just looking at it, just a lot of speculation.
Though being an "Eaton" the gear ratio choices are slim.
So, my shot in the dark is it may have a 4.57 gear ratio.
check all the bolts holding the cover on, and see of there is a little metal tag.
If there is, then it will tell the gear ratio.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 04-11-2010, 08:13 PM   #9
68lngbed350
no metal tag, but i have heard that a metal tag on the rear end means its posi. Is this true?
Old 04-11-2010, 09:44 PM   #10
martindc1
If its identical to the one pictured it is a full floater, meaning that you can take out the axle shaft without taking the wheel off. As far as gear ratio, I'm guessing probably 4.57 or possibly 4.11.
Old 04-11-2010, 11:27 PM   #11
Longhorn Man
what engine and tranny were in it originally?
4.57 and 4.10 were the 2 common ones in single rear wheel trucks.
Old 04-12-2010, 12:02 AM   #12
68lngbed350
tranny wise it still has the stock sm465, the original engine was a 327.
Old 04-12-2010, 11:55 AM   #13
srr
Jack up one wheel. Rotate it through two revolutions. Count how many times the driveshaft rotates= ratio.
srr is offline   Reply With Quote
Old 04-13-2010, 02:20 PM   #14
68lngbed350
thanks alot ssr. I had tried this in the past but I would only rotate the tire once. Leaving me scratching my head. The driveshaft spun 4 and a half times. 4.57's it is.
