Old 04-11-2010, 02:18 AM   #1
spinem
haha, ford guys...
For all you wiring Gu-Ru's
Cheek it outtt
spinem is offline   Reply With Quote
Old 04-11-2010, 02:21 AM   #2
spinem
haha, ford guys...
Re: For all you wiring Gu-Ru's
more
Old 04-11-2010, 02:23 AM   #3
spinem
haha, ford guys...
aaaand more
Old 04-11-2010, 02:29 AM   #4
spinem
haha, ford guys...
+ off batt now goes to cab unfused.-----line says 8g wire, but it has to be bigger, used to supply amp for stereo. ;;;;/w/ new wire. AMERICAN WIRE
+ off alt. goes to + on batt. (direct to terminal) ("8"g wire);;;;;;/w/ new wire. AMERICAN WIRE
exciter off alt goes to +off alt. (fuel proof, heat proof, 40a safe);;;;;/w/ new wire. AMERICAN WIRE
relay wire to exciter= stock.
temp sender=stock
fuel gauge=stock
purple starter wire=stock
ammeter fused links (two 5a) , one went from off firewall to fuse box, and so did the other.
solution?
splice both wires protected by a 10a blade fuse. /w/ new wire. AMERICAN WIRE
ground goes to -on alt and direct to fender.---0g wire;;;;;/w/ new wire. AMERICAN WIRE
questions?
ask away!!!
Old 04-11-2010, 02:31 AM   #5
asphaltburner
asphaltburner's Avatar
Yo! Looks like nice wiring work.
I finished FRANKENTRUCK's just like this prior to engine installation,...complete with looms. It includes MSD ignition wiring. Sure wish my firewall, brake booster, and master looked as pretty as your's! The attention to detail will pay off in the end!
What is the retrograde loom travelling passenger to driver's side across the upper firewall,...I don't recognise that set of wires.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 04-11-2010, 02:35 AM   #6
asphaltburner
Yo! spinem!
No,...I DO see engine wiring coming out of the loom I asked about,...where does the rest of that loom got to when it gets to the passenger side? Heater? Does it continue to the battery?
Todd.
Old 04-11-2010, 02:43 AM   #7
spinem
haha, ford guys...
Originally Posted by asphaltburner View Post
Yo! spinem!
Todd.
that wire loom is my massive + feeding the block on the firewall. I have too many electronics drawing power at once and everything was starved insude the cab...
so i replaced /w/ a surpossid 8g wire direct off battery. it also hides my fuel level wire, purple starter wire, exciter wire and temp sensor!
thanks for the kind words!!!
Old 04-11-2010, 02:45 AM   #8
spinem
haha, ford guys...
i will take more detailed picss tommoro
Old 04-11-2010, 02:51 AM   #9
asphaltburner
Yo! Damn nice job, dude!
I'll watch for more.
Todd.
