Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 04-11-2010, 08:23 AM   #1
mbgmike
Nos 02001 kit
CHEATER Kits 150–250 HP
"CHEATER" Holley 4-Bbl / Carter AFB
Features: * Large Nitrous and Fuel Solenoids
* Adjusted In Matter Of Seconds
* Easy To Install
* Thin 0.5in. Injector Plate
* Ample Hood Clearance
* Includes Necessary Electrical Hardware
Other: The NOS Cheater system is designed for use on 350 CID or larger, carbureted engines. It uses large Nitrous and fuel solenoids and can be adjusted to any desired power level from 150 to 250 horsepower, in a matter of seconds. Cheater systems are easy to install and utilize a 1/2” thick injector plate which fits between the Carburetor and intake Manifold to provide ample hood clearance.
Cheater systems include a 10 lb. Nitrous bottle, four (4) stages of jets, aircraft–quality steel braided line and all other necessary electrical and mounting hardware for a complete installation. Each single Carburetor Cheater system includes Jet Pack #13725 that allows jetting to four (4) different horsepower levels: 150, 180, 210 and 250. Each multiple Carburetor Cheater system includes Jet Pack #13735 that allows jetting to four (4) different horsepower levels: 150, 175, 200 and 250.
Characteristics: Installation Notes
This kit is available without a bottle (02001–NBNOS).
To supply the proper amount of fuel to the Carburetor and Cheater System, a fuel pump must be used that is designed to operate between 5 and 10 PSI, with a flow rate of 0.1 gallons per hour / horsepower at 6 PSI. For example, an engine that produces 450 horsepower when the Cheater System is activated will require a fuel pump that flows at least 45 gallons per hour at 6 PSI.
OUR PRICE $490.00
LESS THAN JEGS OR SUMMIT
IN STOCK AND SHIPS TOMORROW
mbgmike is offline
Closed Thread
