04-11-2010, 10:19 AM | #1 |
Headliner question
Getting close to installing the interior on my project. My question is, were the headliners glued to the roof in any way? I had the upholsterer reback my headliner and am using the original vinyl.
It seems that it's a little too much of a span to just hang in there by the trim edges. |
04-11-2010, 10:47 AM | #2 |
Retired from a track near you!
Re: Headliner question
It is glued from the factory. I have seen some folks use velcro on them to hold them up, I don't like that because of the heat issue. I use a 3M glue out of a 5 gallon can from a local upholstery man. The 3M in a spray can, heavy duty or not, will not hold! Been there, done that ! It will for a while, but lets go pretty quick. Spray the back, and the roof, let them sit a few, before sticking them, it seems to work the best with any glue.
04-11-2010, 11:30 AM | #3 |
i used liquid nails it held it up in place with no problems// whatever glue you use make up a press jig out of 2X4's to wedge it up into place and hold pressure on it overnight till the glue cures
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 04-11-2010 at 11:31 AM. |
04-11-2010, 12:19 PM | #4 |
SWB 4x4 Collector
Same procedure that Cdowns used. Liquid nails and use 2x4's as legs and put a piece of plywood cut to fit as the support. Works well and the glue looks close to the factory type. No problems here except when you might want to remove it later . Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
04-11-2010, 12:20 PM | #5 |
SWB 4x4 Collector
For the record, you may want to leave the last inch around the vinyl loose, so when you stick the trim on, it will leave a nice snug look around the edges. Trevor
04-11-2010, 12:24 PM | #6 |
Truck and auto performance nut
has anyone just glued the headliner and left off the trim? This is what I am considering as my truck doesn't have the slits in the roof for the trim. If so, does it look OK or look like it needs something trimming it out?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
04-11-2010, 12:27 PM | #7 |
its all about the +6 inches
mine is up with liquid nails and no trim. Looks fine. No one has ever even questioned the lack of trim.
04-11-2010, 01:22 PM | #8 |
thats what I figured. Thanks!
