04-11-2010, 03:09 PM | #1 |
Enjoying left field
4bt swap
I've searched around the site, and spent a bunch of time over at 4btswaps.com. I've read a bunch of posts about guys thinking about doing this swap, but has anybody here actually swapped a 4bt into a 67-72 k10? I'm looking to build a 4x4 work truck, that will pull my tool trailer around(maybe 3000# soaking wet), and get good mileage. On 4btswaps.com, there is swaps into everything. There is a guy with an 84 k5, with 1T axles and 37's, an nv4500 and a bone stock 4bt. He gets around 20mpg in town, and it seems to move around pretty good. It sounds like you can boost the power in those pretty easy. There is a company here in spokane that "recycles" Frito Lay vans that have the 4bt's, and most of them were mated to th400's, or sm465's. seems like a pretty easy swap.
04-11-2010, 05:34 PM | #2 |
Re: 4bt swap
There good little engines & very good on fuel but are way underpowerd in stock form (100 to 120HP) & viberate alot more than a 6BT. Not trying to talk you out of it but have you looked into a 6BT?
04-11-2010, 05:50 PM | #3 |
Re: 4bt swap
I used to do a lot of work on Frito trucks back when they ran a lot of these. They were slugish, noisey, smoky, & had a lot of vibration. You had to use a special alternator with big bearings. What about a 6.2 or 6.5 V-8 deisel?
04-13-2010, 01:03 PM | #4 |
Re: 4bt swap
I`d like to check into swapping a 4BT.
04-13-2010, 02:02 PM | #5 |
Factory Strippers Rule!
Re: 4bt swap
I have seen them swapped into all kinds of wheelers here... seem to do alright if you tune them and turn up the boost. I say go for it.
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
04-13-2010, 02:18 PM | #6 |
its all about the +6 inches
Re: 4bt swap
i used to do the installs for frito lay putting that 4bt, ans then 4bta into the p/30 that had a 6.5.
Personally, I'm not a huge fan of the 4b. Very loud, rough, unrefined, and expensive parts... plus slower than a pinto with 2 plug wires missing. |
04-13-2010, 05:43 PM | #7 |
I have a radical idea!
Re: 4bt swap
I agree. I researched them a lot when I was in the "gathering info" stage, and I decided on a 6.2/6.5. I drove a jeep that I guy put a 4bt in, and I would honestly sell my truck if it rattled and vibrated like that thing did. They are durable engines, but not well suited for a pickup, IMO.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
04-13-2010, 05:45 PM | #8 | |
Re: 4bt swap
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 04-13-2010 at 05:47 PM. |
