Old 04-11-2010, 04:41 PM   #1
Wincks2
Front inner wheel bearing removal
Struggling through my first bearing change. This sure is simpler in theory than practice The Haynes manual says to use a screwdriver to pry off the grease seal but I can't tell from the picture which part is the grease seal and none seem to be cooperating easily. Is the part I am to pry off the outer ring I've labeled "Green" or the middle rubber ring I've labeled "Rubber" or the inner metal ring I've labeled "metal"?
Old Smokey: 85 GMC 3/4 ton long bed crew cab originally a 5.7 gas engine now with an 84 6.2 with a 92 serpentine belt system, a banks sidewinder, torque converter, and a shift kit. I bought her this way from someone handy - and now am trying to figure out how all this truck works.
The Old Smokey project: http://67-72chevytrucks.com/vboard/s...d.php?t=390518
Wincks2 is offline   Reply With Quote
Old 04-11-2010, 04:49 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Front inner wheel bearing removal
save your self some hassle take a screw driver or something and go from inside the hub and hit the bearing out it will pop the seal right out...use the old seal between the new seal and your hammer when banging the new one back in
Hottrucks is offline   Reply With Quote
Old 04-11-2010, 04:50 PM   #3
LONGHAIR
The "green" and "rubber" are the same part. The "green" is a metal ring used to hold the rubber seal in place. The part you labeled "metal" in the inner cone of the wheel bearing itself...
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-11-2010, 05:09 PM   #4
Wincks2
Thank you very much Hottrucks and LONGHAIR.
Old 04-11-2010, 05:20 PM   #5
diamondjimtwo
diamondjimtwo's Avatar
There is an easy way to do it without tools. After you remove the spindle nut and outter bearing. Reinstall the nut. Grab the rotor and pull on it. The nut will hit the inside bearing. You will have to pull it a few times hitting the nut. Once the bearing/seal break loose, they will stay on the spindle and the rotor will come off. Remove the nut along with the old bearing and seal.
Hope my directions make sense.
1979 Blazer
1991 Jimmy (Sold)
diamondjimtwo is offline   Reply With Quote
Old 04-11-2010, 08:11 PM   #6
Wincks2
Thanks diamondjimtwo
That may also prevent denting the parts while hitting them.
