04-11-2010, 06:36 PM | #1 |
body work.
Ive never done body work and wanted to start on my 87 its got surface rust mostly so how and what would i use to fix this and any tips for a beginner? Thanks
04-11-2010, 08:27 PM | #2 |
The One And Only !!!
Re: body work.
Well, You can start by gandering around in this section;
http://67-72chevytrucks.com/vboard/f...splay.php?f=16 Do some searching first and if you don't find answers to your questions start asking there......
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
04-11-2010, 08:34 PM | #3 |
Re: body work.
Start on one part of the truck. Pick a fender or a door and get to sanding on it. You don't have to take it to bare metal. I like to find the highs and lows and if I can get to them I'll hammer them out but if not a nice layer of bondo will work too. I like the stuff 3m has out, it's called sand blaster. Paint and bondo don't stick to the sandpaper so you can go a long ways with your paper. I just started using tape around areas that I need to bondo. I think it helps. You don't have extra bondo to sand.
