Old 04-12-2010, 09:10 AM   #1
Chris65GMC
Upper Steering Column Beareing
Anyone know where the best place to get the upper steering column bearing would be? LMC says they dont have them, I read a post on here saying that the one from brothers was poor quality, and another post which implied that the bearing is part of the turn signal assembly. Any help on this matter would be much appreciated.
Thanks,
Chris
Chris65GMC is offline   Reply With Quote
Old 04-12-2010, 09:29 AM   #2
DPowers
DPowers's Avatar
Re: Upper Steering Column Beareing
Try here-
http://www.truckandcarshop.com/6072.html
DPowers is offline   Reply With Quote
Old 04-12-2010, 03:02 PM   #3
mikie 1954
when you get yours be shure to tell them that it is a gmc. mine is a 64 and i had to get an older model one ,chevy changed i think in 63 ,gmc lateralthuogh not shure when. i presume you have a gmc Chris65GMC.
mikie 1954 is offline   Reply With Quote
Old 04-12-2010, 06:28 PM   #4
lakeroadster
I just talked to Tony Smith (Lilred66, 4-5-6-trucks) about this on Friday 04-09-2010. I am in need of the upper bearing also, as well as a upper bonnet and secondary bonnet (column housing pieces).
Tony stated that the upper bearing indeed does come with the turn signal switch, but we were talking about a Chevy, not a GMC.
LMC lists a different P/N for the GMC 36-0603. The Chevy P/N is 36-0604. http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=88
Classic Parts has a color picture that shows the bearing in place for their Chevy switch P/N 53-508 http://www.classicparts.com/1964-66-...ctinfo/53-508/
You might want to give Tony a call, he can probably set you up with the right information.
Tony Smith
4-5-6 Chevy Trucks
560 South 11th Street
Kansas City, KS 66105
4-5-6chevytrucks@sbcglobal.net
913-207-7789
lakeroadster is offline   Reply With Quote
Old 04-12-2010, 07:39 PM   #5
Chris65GMC
Thanks for the replys. I wonder if this is what i need?
http://www.classicparts.com/1964-72-...info/76%2D815/
I hope it looks better than the one in the picture!
Chris
Old 04-12-2010, 07:44 PM   #6
lakeroadster
That's the one I have in my 65 Chevy. I too was not impressed, pretty whimpy, don't ya think?
And it mounts in the turn signal plastic switch mechanism... I guess I just expected something mounted to a steel sleeve, not plastic.
Old 04-12-2010, 08:22 PM   #7
mikie 1954
I got mine from the truck and car shop. the differace between the two is one has a horn wire attached and one doesn't.
