Old 04-12-2010, 11:35 AM   #1
panhandler62
Java Mechanic
panhandler62's Avatar
Top mount for rear airsprings (trailing arm)
I'm mocking things up and I see that my bags center up in the frame (and c-notch re-enforcing plate!) real well, which is more likely attributable to Nathan Porter having made the trailing arms correctly than anthing I did.. lol
What I want to check before I move on is if I need a mounting plate on top. The bags are wider than the frame section. They frame section is very heavy here (thanks to the notch plate) so I'm not worried about it buckeling but I thought I should ask y'all if it's ok to simply bolt (and plumb) them through the frame or if I should make a plate (w/wo gussets?) that covers the entire width of the bag.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 04-12-2010, 01:26 PM   #2
SCOTI
SCOTI's Avatar
Re: Top mount for rear airsprings (trailing arm)
No need for the full diameter plate. There's enough material to support the weight as is.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-12-2010, 01:34 PM   #3
panhandler62
Java Mechanic
Cool.. thanks.
Guess I need to doing some drilling and reaming and then get to cleaning up the third member. (It needs new seals and I'm going to take the opportunity to replace the shoes while it's out of the truck and easy to get to since that is such a pita with the HO52 rear end.
Keith
