Old 04-12-2010, 07:41 PM   #1
Cdshinne
Cdshinne's Avatar
WTB 3/4ton brake booster bracket
Need a brake booster bracket with the linkage to the pedal for my 72 k20. Thanks Chad
1972 K20 lwb
2000 Z71 x-cab
1970 ford f100
Cdshinne is offline   Reply With Quote
Old 04-12-2010, 08:56 PM   #2
Todd68Chevy
Todd68Chevy's Avatar
Re: WTB 3/4ton brake booster bracket
I have a 1972 C20. Would it have the correct booster set up for you? I am parting out the truck if it is the bracket you need let me know. It would be a couple days before I could get it taken off. Thanks, Todd
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 04-12-2010, 08:56 PM   #3
w314speed
I believe, the bracket and gizmo to the pedal are the same on 10-20-30. The booster is larger than the 10, and the bracket from mastercylinder to fiewall is 2" longer for the 20-30, due to the larger booster! Hope, that helps for local parts!!
w314speed is offline   Reply With Quote
Old 04-12-2010, 09:11 PM   #4
Cdshinne
Cdshinne's Avatar
Thanks for the info w314speed it does narrow my search down considering i have the c10 gizmo already I just thought they would be different.
Todd I already have a new booster so if you would separate them that would be great! By the way i am new on the classifieds and i don't know if you would send me a pm or what so maybe you could help me out alittle
Thanks Chad
1972 K20 lwb
2000 Z71 x-cab
1970 ford f100
Old 04-12-2010, 09:27 PM   #5
Todd68Chevy
Thanks Chad
I do not mind breaking it up, I just need to be able to get it apart. So what do you need?? You have the push rod?? Do you just need the bracket between the booster and the firewall and the brace from the booster/ master cylinder to the firewall? Let me know and I can check the conditions better.
We can send a PM with payment and address info if we work something out, otherwise it should be posted for everyone to see whats going on (as per forum rules) Thanks, Todd
Old 04-13-2010, 05:19 PM   #6
Cdshinne
Cdshinne's Avatar
Todd I just need the bracket and pedal rod. I don't know how much you want for it but just send me a pm and we will work something out.
Thanks Chad
1972 K20 lwb
2000 Z71 x-cab
1970 ford f100
Old 04-13-2010, 10:13 PM   #7
Todd68Chevy
Thanks Chad
PM sent, Does anybody know if the big block trucks were the same as the small block trucks because I think this 72 bb 3/4 ton has 6 bolts holding to the firewall and the 72 sb 1/2 I took apart only had 4 bolts. Would that be because of the sb / bb or the 1/2t / 3/4t. Thanks, Todd
Old 04-14-2010, 09:11 PM   #8
Todd68Chevy
I got it taken off tonight and here is a couple pictures. This is off of a 1972 C20 Big Block truck. This includes the rod between the pedal and pivot, the pivot and booster mounting bracket and 2 braces that run back to the firewall for support. I am also including the rod to pedal bolt and other hardware that was removed during disassembly. Let me know what you think. Thanks, Todd
