Old 04-12-2010, 08:17 PM   #1
neba
GM12 bolt
trying to identify what gears i have in GM 12 bolt. can find casting numbers but no stamped numbers. NF 3896839. has a plate with springs in center that i havent seen before.
neba is offline   Reply With Quote
Old 04-12-2010, 08:19 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: GM12 bolt
whats the specs on your truck?
John
1999 Toyota Tacoma 4x4
Old 04-12-2010, 08:25 PM   #3
neba
Re: GM12 bolt
69 chevy C10 long bed 350v8 400 turbo
Old 04-12-2010, 08:27 PM   #4
kgt
Re: GM12 bolt
sounds like a posi, out of a car, the springs with a plate reminds me of that style as opposed to the centrifical style in the trucks. When you say identify, do you mean you want to know the gear ratio of the set, if so divide the ring gear teeth by the pinion and that number is the gear ratio..
kgt is offline   Reply With Quote
Old 04-13-2010, 05:42 AM   #5
LMN8UR
LMN8UR's Avatar
Re: GM12 bolt
Just because you find codes, doesn't mean a previous owner didn't change them. Do you have a tach, is your speedo right, do you have a posi?
72 Chevy C-10 Custom LWB
383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb.
Hooker Comp Headers w/ X-Pipe and 2.25 duals
TKO-500 & 3.08:1 rear
I Love HEMI's, they're soft & chewy!
LMN8UR is offline   Reply With Quote
Old 04-13-2010, 11:27 AM   #6
neba
Re: GM12 bolt
never thought of something so simple as counting teeth. or the fact someone could have changed it. found it has a 3.73 does the plate with springs behind pinion indicate its a posi?
Old 04-13-2010, 11:55 AM   #7
Fitz
Re: GM12 bolt
on the left open carrier on the right Eaton Posi
Fitz is offline   Reply With Quote
Old 04-13-2010, 01:38 PM   #8
neba
Re: GM12 bolt
bought this truck over the winter so my goal was to change fluid and inspect gears. gears appear to have nice even wear pattern.fluid didnt show anything unusual.next my curiosity asked what gear ratio which i now know is 3.73 now im wondering if its an Eaton. the ring gear has a GM stamp and part # 3817778 would an Eaton diff have GM gears.it looks like picture Fitz posted. my lack of computer skills is preventng me from sending picture
Old 04-13-2010, 03:21 PM   #9
Fitz
Re: GM12 bolt
The center section can be Eaton, Detroit Locker, open or whatever the factory or previous owner might have put in the housing. The center I posted was an Eaton BUT that does not mean thet the entire differential is an Eaton! The Eaton Diffs were installed by the factory only on 3/4 ton trucks and they have a totally different outer case. The cover looks like a car 10 bolt on steroids but, as has been pointed out here before, the number of "bolts" refers to the number of fasteners attaching the ring gear to the center section and only coincidentally matches up with the number of bolts holding the rear cover in place. In the case of the GM 1/2 ton truck and some car housings, the numbers are the same but really arent a guide.
As Shaky pointed out in the thread "rear end curiousity" a true 3/4 ton Eaton differential somewhat resembles a GM 10 Bolt differential which is obvious from his photo below:
Old 04-13-2010, 03:46 PM   #10
neba
Re: GM12 bolt
so it seems the center parts are Eaton. doesnt look like it has clutches like some GM units had. does it require a lube with additives for posi, $18 a quart or regular lube $4 a quart? thanks for the help.
Old 04-13-2010, 03:52 PM   #11
cdowns
cdowns's Avatar
Re: GM12 bolt
get poyal purple gear oil it has the additives in it and the synthetic is far superior than the economy stuff
