Old 04-12-2010, 08:25 PM   #1
glimmertwin01
glimmertwin01's Avatar
203 to 205 conversion
I have a 74 K5 with a 203 and locking hub .... not sure if its Part time or full time
OK i found a 70 with a 205 the bearing race appears to be the correct size along with the splined shaft that goes into it on my TH350... the only issue appears to be the istance from the mouning flange of the 70 T case support on the tranny side to the center of the U joint for the rear drive shaft is about 16 inches...the rear flange of my dead TH350 in the truck to the center of the U joint is about 20 inches... does this seem right? or do i need a shorter rear shaft from 73-80 a SM465/205 set up? heres some pics..the white tranny is a working TH350 than needs to go into the 74K5... and some of the donor 205... or should I just say bag it? and o with the 203?
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 04-12-2010, 10:35 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: 203 to 205 conversion
The 205 you have there has the TH350/TH700 adaptor on it. As for the length for you dl, The 203 and 205 are different lengths. This also depends on which tail housing the t case has. Without more info and pics I would say adjust your dl to fit.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 04-13-2010, 06:32 AM   #3
glimmertwin01
thanks
68 K15 V6 LWB.
74 K/5
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
