Old 02-08-2003, 12:00 AM   #1
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
storing an engine
how do i prep an engine to be stored. it's gonna be about 2 yrs before i will be able to drive my gmc. what should i do to prep it? i'm gonna change the oil and it'll still have the tranny attached. any other ideas?
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 02-08-2003, 12:53 AM   #2
jhow66
jhow66's Avatar
I take it that it will be in the garage where you will be working on your truck. Just take out plugs and squrit some oil in each hole. Then every 2 or 3 months turn engine about 1/4 turn--this will change which valve spring is compressed. Should be fine.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-08-2003, 04:53 AM   #3
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
if it's running, slowly pour a quart of transmission fluid down the carb, adding a little at a time, keeping it at about 1500-2000 RPM, till the fluid fouls all the plugs and kills the engine....it will keep forever. Next time you start it, it will smoke like a freight train for awhile, but will clear up.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 02-08-2003, 07:15 PM   #4
Yellow Cheyenne
Fogging or oiling the cylinders is good advice. Also, back off all the rockers during storage. This will prevent any moisture from entering the combustion chamber from the exhaust or intake and will also prevent any collapsed or lazy lifters when you restart. Eastwood also offers some deals to replace the spark plugs that will keep the air dry in the combustion chambers (dessicant plugs).
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
Old 02-11-2003, 11:25 AM   #5
yellowgmc
yellowgmc's Avatar
cool. thanks
1972 GMC 1500
1994 F-150 XL 4x4
