Old 04-12-2010, 11:59 PM   #1
jake wells
rear shocks
will rear shocks from a 3/4 ton work on a half
thanks
jake
jake wells is offline   Reply With Quote
Old 04-13-2010, 03:28 PM   #2
stevieB
stevieB's Avatar
Re: rear shocks
Good luck with this, I posted a shock questions three times, never got a response. I do not think there is alot of shock knowledge on here.
Here is a bump, so it doesnt get buried right away.
stevieB is offline   Reply With Quote
Old 04-13-2010, 05:15 PM   #3
Slofarmtruck
Re: rear shocks
I just looked up rear shocks for my 86 C10 and an 86 C20 and it listed the same part numbers. Remember its the springs that give the truck its ride height and cargo capacity. The shocks are for ride quality. They should be interchangeable.
Slofarmtruck is offline   Reply With Quote
Old 04-13-2010, 05:50 PM   #4
Kalashnikov46
Kalashnikov46's Avatar
Re: rear shocks
they should work. infact most shocks will work unless your lifting your vehichle or rock crawling.
Kalashnikov46 is offline   Reply With Quote
Old 04-13-2010, 09:11 PM   #5
RuralRoute C-30
RuralRoute C-30's Avatar
Re: rear shocks
From the way I understand it, if one were ordering shocks from LMC, (a handy reference at times if nothing else), looks like there isn't any difference. http://www.lmctruck.com/icatalog/cc/full.aspx?Page=51
Agreeing that the shocks are just there more for ride and stability while the springs are what handles any real weight.
I do know before I replaced the shocks on the C-30 the rear was hopping all over the place with the slightest bump. Now it doesn't. As I understand it, that is why Chevy went with the staggered shocks in the rear to get control of "wheel hopping" in the back.
New front shocks definitely added to a more comfortable cab ride too. Worth the expense if needed. Just be prepared, as I wasn't, when taking them off, that chances are some idiot may have used an impact gun when installing the old ones!
Took a breaker bar to get the front ones removed.
Mark
1985 Chevy C-30 Hydraulic Dump Bed
2001 Saturn SC2 (go to work car)
2010 PT Cruiser (wife's car)
"Reality is just a hallucination brought on by lack of alcohol."
RuralRoute C-30 is offline   Reply With Quote
