Old 04-13-2010, 01:02 AM   #1
buckshot305
Rear Disc Brake Kits
I'm building a 5 lug 12 bolt for a 87 SWB/2wd, and I'm thinking about putting a set of discs on it. I ran a SSBC rear disc kit on a 6 lug 12 bolt on a 83 K10 and didn't have very good luck with it. With the truck on jackstands, idling in gear (4spd) you can stand on the brake pedal with everything you've got and the rear brakes won't stall the engine. I would think that a light tap on the pedal should instantly lock it down and kill the engine. (In 4wd the fronts will do exactly that)
I have installed a 4 wheel disc proportioning valve from Inline Tube, and I have bypassed the PV with a run of straight 1/4" brake line from the MC to the rear. I have tried at least 3 different MCs including a Corvette MC. I also have a brand new booster. And yes, I have thoroughly bled the system.
I pretty much given up on it. Does anyone know what combination of master, prop valve, etc I need? I have also wondered if I need to run 3/16" Line to the rear (the front is 3/16 and the rear is 1/4 from the factory). Would smaller line increase pressure? I was close to buying a 3000psi gauge at the time to troubleshoot the issue, but never did.
If anyone is running a SSBC kit with the single piston calipers with integrated parking brake, please let me know how it turned out. Is there any kind of mechanical adjustment on the calipers themselves?
Finally, I'd like some input on other kits to look into. I'd be interested in something reasonably priced, that works well and has a drum style parking brake.
Thanks,
Travis
buckshot305 is offline   Reply With Quote
Old 07-21-2010, 09:21 AM   #2
ERBSIX
ERBSIX's Avatar
Re: Rear Disc Brake Kits
Truckin' Magazine just did a great article on a C10 Brake Conversion to disc.
78 Silverado 1/2 Ton LWB (restore)
78 Silverado 3/4 Ton LWB (parts truck & practice - eventually a work horse)
My Build thread: http://67-72chevytrucks.com/vboard/s....php?p=4082128
Ellis Benus - Web Design Columbia Mo & Google Fan Boy!
ERBSIX is offline   Reply With Quote
Old 07-21-2010, 10:11 AM   #3
twoodson
I like the Blackbirds kit; I believe Travis (TVBlazer) used it and I believe a few others on the board has used them and they like. I have spoken with Randy the owner and he seems pretty good to deal with. www.blackbirdscustomtrucks.com
twoodson is offline   Reply With Quote
Old 07-21-2010, 10:33 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Take a look here- Truckin Magazine Replaces C10 Brakes with Baer There is a thread going on the same subject that might answer many of your questions.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
