Old 04-13-2010, 09:02 AM   #1
Alex1
Alex1's Avatar
On last question before I order the wheels
I'm ordering a set of rally wheels for my 1980 Step and I'm going with 8" wide in the front and 10" in the rear. I noticed they offer 4.5" or 5" backspacing - any one have an idea which is better?
Alex1 is offline   Reply With Quote
Old 04-13-2010, 10:18 AM   #2
justpball
justpball's Avatar
Re: On last question before I order the wheels
the lower the number the more they stick out of the fender, and our trucks in the rear are a narrower track then the front, are you planning on bagging your truck so it tucks the tires?
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 04-13-2010, 10:47 AM   #3
Alex1
Alex1's Avatar
The most it will be lowered is 3/4.
Old 04-13-2010, 11:02 AM   #4
justpball
justpball's Avatar
then it is not going to matter that much with just a 1/2 in diff, I would go with the 4.5
87 Crew SWB
Build for the crew
90 burb 2wd
Old 04-13-2010, 11:25 AM   #5
Alex1
Alex1's Avatar
It should be OK with a 315 - 60 -15 -I just don't want the tires/wheels to stick out.
Old 04-13-2010, 12:41 PM   #6
justpball
justpball's Avatar
here is a pic of my burb, the front is a 18x8 with a 4inch back space, and the rear is a 20x10 with 5in back space, look how far they sit in, also on the front I have drop spindels so it pushes my front wheels out about 3/4 of an inch.
87 Crew SWB
Build for the crew
90 burb 2wd
Old 04-13-2010, 02:54 PM   #7
Alex1
Alex1's Avatar
Also are the wheel studs 1/2" or 7/16"?
