replace gasket 700r4
Was wondering if anyone knew what I should torque the pan bolts to when I replace it, and what pattern to tighten them with. Also if you have done it before does a swivel work for the bolts covered by the cross member, or is there another trick? Thanks for any help!
18 Till I Die
Re: replace gasket 700r4
I undid the back mount bolt and jacked up the back of the tranny with a 2x4 at the tail housing. I had to push it right to the top till it hit the floorboards but that the only way the pan will come off without pulling the cross member. And yes a swivel helps.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
Thanks for that!
Parts and more parts
When I do a tranny pan, I use a 1/4" drive ratchet and long extention with a short socket. That combination keeps me from overdoing the torque on the pan bolts. Tighten them to a snug condition in a cross pattern on the pan and then go around and snug them one last time to set the gasket crush. The 1/4" drive extention will get into many spots that the 3/8" cannot slide through. You may have to loosen the rear tranny mount bolt and lift the tranny slightly, but that is all.
Frank |
Well I got it done. Bad news is it still has a small leak near bellhousing it drips out of the little drain hole in the access panel. I think I might just take it to a shop. The pan gasket is all I feel comfortable doing on my own. Thanks for the help!
18 Till I Die
If you have a drip from the front inspection cover hole then its probably a front torque converter seal. They are not hard either, but the tranny has to come out then.
