04-13-2010, 06:19 PM | #1 |
power window help
Having problems with my power windows.I replaced both motors,but still had troubles.Foound loose wires at the switch connections.Sodered those,and that lasted a while,but now you have to squeeze the connector to make it opererate.I have not been able to locate a replacement connection and pigtail.Any help will be greatly appreciated.It is the drivers side on my 86 c10.
04-13-2010, 06:52 PM | #2 |
BMW & ASE Master Certified
Re: power window help
probally can get a pigtail from the bone yard... I plan to create a harness for my factory power windows... I dont like all those amps going through that switch.... over time those arcs will cause the switch to fail or have "dead spots" on it... with a relay, its designed to take abuse and they are only about 2 bucks for th relay, vs 25 for the switch. take the blue twist nut off and clean those contacts, do one at a time or disconnect the battery. that should help
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
04-13-2010, 07:06 PM | #3 |
Getting Old; Going Broke
Willing to get salvaged and splice it in? Try car-part.com and see if any salvages show a door loom. You might be able to get them to just sell you the connector and a short pigtail, chances are they'll want to sell the entire door loom. Still I'd think for $25 you could get that.
