04-13-2010, 07:25 PM | #1 |
LT1 / 4L60E Swap?
Has anyone put a thread together for doing a LT1 / 4L60E swap into their pickup?
04-13-2010, 09:49 PM | #2 |
Re: LT1 / 4L60E Swap?
If you find one let me know otherwise I'll have to do one once I finish up my LT1 swap. If everything goes as planned I hope to start the truck this weekend.
- Brian
1963 Long Bed C10 - LT1/4L60E Swap in Progress. Blew up the straight six and happened to have the engine trans combo on hand already. 1995 Impala SS - LT1/T56 Combo. This is my 1st priority project. |
04-13-2010, 10:14 PM | #3 |
i am also in the process of putting one in but its on hold for the time being all i have left is the fuel system if you have any questions let me know
04-14-2010, 12:14 AM | #4 |
I plan on doing a suspension conversion this summer, but Im also going to be looking for a Caprice to rob a motor and transmission out of. Just more curious how everyone elses swaps went or are going. Any info will help prepare me for the adventure.
04-14-2010, 12:34 AM | #5 |
60-66 Nut
There is a member here that is doing a LT1/4L60E swap, I just can't think of who it is. Have you looked thru the 'Projects and Builds' section? Might be in there.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 04-14-2010 at 12:34 AM. |
04-15-2010, 10:47 AM | #6 |
I found a 1994 Camaro Z28 with a good core motor for $650. The guy drove it at 270 degrees and burnt up the heads. Now there is water in the oil. Sounds like a blown head gasket to me. Does anything think this is worth buying to start my conversion with?
04-15-2010, 07:18 PM | #7 |
I got the 90k mile caprice LT1 currently in my impala for 600 bucks. I'd be worried about the excessive heat on the aluminum camaro heads. Who knows what that does to them. For the record I often spin my junkyard block to 6k with the manual set up. I scored a complete wrecked impala ss for 500 and am using that engine/trans in my truck. Along with a host of other pieces. (new leather seats for my car wasn't bad either.)
I guess I'm saying I'd avoid the 650 possible rebuild canidate for one that was a known runner when pulled preferably by me or someone I know. - Brian
04-15-2010, 07:31 PM | #8 |
I am in the middle of an LT1/turbo400 swap in my 64. Not sure how much different the 4L60E is form a 400. the rear cross member would be the concern I would think.
04-15-2010, 07:36 PM | #9 |
Uh realized what I was saying was wrong. Ignore this.
- Brian
1963 Long Bed C10 - LT1/4L60E Swap in Progress. Blew up the straight six and happened to have the engine trans combo on hand already. 1995 Impala SS - LT1/T56 Combo. This is my 1st priority project. Last edited by sshockr; 04-15-2010 at 07:43 PM. |
04-16-2010, 01:06 AM | #10 |
60-66 Nut
That might not be a bad deal if it's the whole car for $650 and if the trans is good. That way you'd have the whole harness, PCM, trans, rear disc brakes. etc. I would say you will want to have the heads checked over and tested for cracks. That could have affected the rings as well.
04-16-2010, 01:32 AM | #11 |
Resistance is Futile
I'm afraid of anything thats gotten too hot....I wouldnt buy something with a leaky radiator, for that matter. I'd be afraid of the block; I got a cracked 400 before. Ran great until it was hot and puked water out the exhaust and made a milkshake in the oil pan. Jus' sayin'
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
