Old 04-13-2010, 07:42 PM   #1
thepunisher
thepunisher's Avatar
Rust Rust Rust Where to Start?
These photographs are from the passenger side of my truck. Where do I start for repairs? Do I start inside and work my way out (cab floor, inner rocker, outer rocker then cab corner)? Or do I start with the cab corner and work my way in?
Also who sells that section of floor, I probably need both side and about the same sizes.
Blayne
thepunisher is offline   Reply With Quote
Old 04-13-2010, 08:01 PM   #2
tim21391
tim21391's Avatar
Re: Rust Rust Rust Where to Start?
id do your floor first its easier then u dont gotta worry about tearing up your new metal its also easier.. wes from classic heartbeat is a good guy and help ya get squared away thats where i got some of my metal from.. he has this piece that goes in from the door jam of the floor 4 inches in the floor which is also your inner rocker.. its $100+ a side but well worth it.. id do floor then the section of floor by your tank.. i just used a flat piece of metal and a hammer and clamps to do mine since nobody will really see it.. then do your cab corner and rocker and then your support.. it might be easier to do support first then corner but who knows check out my build thread in my signature i did a lot of rust repair and i got pics you can check out.. let me know if ya got any questions since i ran into a lot of situations on mine that i could probably help you with
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-14-2010, 01:54 AM   #3
culp7
HickTown
culp7's Avatar
Ttt
1993 Ford Mustang Vert w/ 2.3
1969 Chevy C/10 w/350
1968 Chevy C-20 w/250
1976 Dodge Aspen W/ 225
2000 Toyota Tundra w/4.7
1987 Dodge Ram D-100 w/360
255/70-15
___________
(oo)══╬══(oo)
culp7 is offline   Reply With Quote
Old 04-14-2010, 08:18 AM   #4
Shyguy
Junior Member
Shyguy's Avatar
I have a '67 that is about in the same shape so I will be following your progress.
Since I have never done any rust repair I am going to start working on my '71 first because it is not really that bad. Hopefully doing the '71 will give me a chance to practice before I tackle the '67.
Good luck and please keep us posted on your progress.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-14-2010, 09:30 AM   #5
lks dcvn
lks dcvn's Avatar
First thing I would do (and did do)...
Research in the Projects and Builds Section of the 67-72 forum.
That can provide valuable insight into how these trucks are put together and how to fix the rust.
That is free, but will take some time to find the right posts to answer your questions and see pix on how to do it. I spent weeks looking at the site taking notes on how stuff was replaced/repaired, etc.
More direct route - www.ebfabman.com - the videos show in detail how to fix what you are looking at on your truck [and any other 67-72 truck for that matter]. It may cost you some $ - but it will show you step by step what to do, the order, how to approach the fix, etc. Well worth it.
Where to find the patch panels - I would look for the closest place to you since shipping the metal you will need - will add up quick.
Good luck!
lks dcvn is offline   Reply With Quote
Old 04-14-2010, 12:03 PM   #6
red69ss
Burnouts are therapeutic
red69ss's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=318544
look at this build thread its very detailed and I believe he replaced about all the same metal
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 04-14-2010, 02:14 PM   #7
thepunisher
Thanks guys, I've thought about efabman's videos, that would be a $100 well spent. I'll go through the thread that red69 posted. I'll also update this thread as I go along. I plan to continue to remove rusted material to get an idea what additional sheet metal I need. I already have the inner/outer rocker panels, cab corners, and the rear floor support. I was going to just use flat sheet metal to repair the floor. I agree with tim, nobody is going to see it. I am concerned about it being structurally sound since the seatbelt is bolted right next to the hole. I am in the process of sandblasting the rear frame and relocating the gas tank. As soon as the gas tank comes out of the cab I'll start in on this.
Blayne
Old 04-14-2010, 04:33 PM   #8
tim21391
tim21391's Avatar
ya keep us posted i know were all eager to see how it goes
Old 04-14-2010, 05:26 PM   #9
Pickupmanx2
Buy my truck and save yourself time!
SEMPER FI
96 F350 CC/4X/7.3/ZF5
77 F150 SB/4X/NP435/NP205
70 C10 400/400
63 F250 4X/T98/NP205
Pickupmanx2 is offline   Reply With Quote
Old 04-15-2010, 10:31 PM   #10
bean
Just bought the above mentioned piece from Wes for the drivers side of my truck today. Can't wait to get it.
bean is offline   Reply With Quote
