04-14-2010, 02:59 AM | #1 |
Moderator
1972 3/4 ton front and rear ends complete
I have a complete disk brake front end for sale from a 72 C/20 truck. I just removed these and will not be using them on my project. The brake pads are good, had a brake job 3 years ago, and less than 500 miles since. The bearings look good. Included are the rotors, calipers, spindles/dust shields, upper and lower control arms, sway bar, springs, tie rod ends and centerlink. Local pick up in So Cal. Board member Sinister has first dibs on this. $100 SOLD
I also have the factory leaf sprung Dana 60 rear end. It is code RKH, which is 3:54 open diff. It is complete, drum to drum, with good brake shoes as brakes were also done less than 500 miles ago along with the front end. The e-brake cables are also included, as well as the factory leaf springs/shackles, overload springs, hard brake lines/rubber hose, and the 4 bump stops that bolt to the frame. The diff was also serviced at the time of the brake job. It does not leak. This is a bolt-in-and-go application. Local pickup in So Cal also. $150 SOLD I have the four factory wheels and tires for sale. They are 8 lug, 16.5", NON-split rims with size 16.5 x 9.50 tires with about 50% tread left. Local pickup. $50
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 04-17-2010 at 03:55 AM. |
04-14-2010, 03:00 AM | #2 |
Moderator
Re: 1972 3/4 ton front and rear ends complete
more pics
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
04-14-2010, 05:26 AM | #3 |
i'll get in line for the overload springs and 4 bump stops, if you will separate? thanks, dan
04-14-2010, 08:09 AM | #4 |
Between Trucks...
Hey Scott, when would be a good time for me to pick up the brake stuff and sway bar? You can PM me the details.
Beat it to fit, Paint it to match... |
04-16-2010, 02:09 AM | #5 |
Moderator
Dan- I will separate. The 4 bump stops are $40 shipped to your door. The overload springs are very heavy and IMO not worth the shipping. Here are some pics showing the bump stops attached to the frame. They clamp on to the framerails. First pic is passenger (right) rear outside, second pic is passenger side front outside, third pic is passenger rear inside, fourth pic is passenger front inside. You can copy these pics for reference, as I would need to disassemble them for shipping. Let me know. Thanks, Scott
04-16-2010, 02:11 AM | #6 |
Moderator
PM sent.
04-17-2010, 03:56 AM | #7 |
Moderator
Front end and Dana 60 have sold. Bump for the tires/wheels. New Price is $50 picked up.
04-19-2010, 08:00 PM | #8 |
Moderator
I posted pics and a price. Are you still interested in these?
05-03-2010, 09:15 PM | #9 |
Moderator
Bump. $50 for the tires/wheels picked up.
$30 shipped for the overload bump stops.
05-04-2010, 12:09 AM | #10 |
Do you have the brackets that attach to the trucks frame and then go to the motor mounts?
If you do can you send me a picture of them And how much are you asking My zip is 33908 Fort Myers FL.. Thanks Capt Kurt |
