Old 04-14-2010, 08:07 PM   #1
jay55jay
changing manual tranny oil
I was looking at the tranny today and I am wondering how to check and change the oil. I see the bottom plug I could not see another one.
jay55jay is offline   Reply With Quote
Old 04-14-2010, 08:26 PM   #2
Slofarmtruck
Re: changing manual tranny oil
Might only be one plug on it which would require you to suck out the old fluid with a pump and fill with new fluid up to that hole.
Slofarmtruck is offline   Reply With Quote
Old 04-14-2010, 10:20 PM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
If theres a plug on the bottom of it has to be one on the top cause can't fill it other wise. If theres only 1 plug will be on top. What are you working on?
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-15-2010, 07:30 AM   #4
jay55jay
It's a 87 chevy c 10 with a 4 speed I have never checked the fluid in it or the rear do they both take the same gear oil?
Old 04-15-2010, 10:15 AM   #5
James McClure
One shot, one kill.
Same oil?? Mabey, mabey not. Is it a 465? (big cast iron case with a granny low gear) If it is use the same lube (80W 90) in trans and rear end(s). If not it will use ATF. Transfer cases (aluminum) use ATF. Heavy cast iron transfer cases use (80W 90) ALL differentials use 80W 90. The 465 has 2 plugs both on the left side, one high on the case and one at the bottom. Drain lube, replace pulg and fill until runs out the upper plug, about 4 quarts should do it. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 04-15-2010, 11:00 AM   #6
jay55jay
Yes it's the granny tranny big square box it has a plug dead center on the bottom in the middle I didn't see any other plug
Old 04-15-2010, 07:04 PM   #7
fpjr0
fpjr0's Avatar
I used to work in a lube center for years, just dont remember,,, the plug at the bottom is the drain and their has to be another plug the same size on either side, just can remember..
ONCE YOU GO LS, YOU NEVER WANT LESS!!
fpjr0 is offline   Reply With Quote
Old 04-15-2010, 08:03 PM   #8
jay55jay
I have to look at it better. So I have not really taken it out on the highway yet. What do the granny trannies typically cruise at. I have a 350 in the truck
Old 04-16-2010, 05:04 AM   #9
donut
donut's Avatar
There's no OD, so rpm would depend on your rear gears and tire size.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 04-16-2010, 09:20 AM   #10
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
There are 2 Plugs on a SM465.
i use 75W90 Mobile Lube
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 04-16-2010, 07:36 PM   #11
Oilbrnr
Oilbrnr's Avatar
Look closer, there is a fill plug on the side. IIRC it is on the passenger side, though the pic above would contradict that...
None the less, it is there.
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 04-16-2010, 07:45 PM   #12
jay55jay
I found the plug half way up on the drivers side. About how much gear oil should i buy for it off hand.
Old 04-16-2010, 08:01 PM   #13
Oilbrnr
Oilbrnr's Avatar
half gallon. Better to have to much and return one than being short in the middle of the job. It is enough of a PITA that you want to get'r done in one shot! I hate the smell of hypoid oil!!!
-Don-
'04 Denali XL
'05 DMax CCLB 4x
