Old 04-14-2010, 09:52 PM   #1
Murphy IRE
Frnt drive shaft advice w/ 700R4 tranny
The PO installed the 400sb and the 700R4 tranny. They cut the rear drive shaft and did it right. However, they never extended the front drive shaft. So it was just holding onto the end of the splines. Any hard 4x4 action and it would have poped off and hit the pan on the tranny. So if you convert to a 700R4 make sure they lengthen the shaft. My splines are shot so I have a complete new shaft being made. I'm going with the new teflon greaseless fitttings, front and back. Total job $300. I've seen their work and it is first class! It is a real bugger to remove the front drive shaft. The cross support bar makes it almost impossible, it will take a small/skinny 1/2 in combo wrench!
Murphy IRE is offline   Reply With Quote
Old 04-15-2010, 08:38 PM   #2
84 400
Sb 400 club
84 400's Avatar
Re: Frnt drive shaft advice w/ 700R4 tranny
Another good tip is don't jump for a new shaft right away. IF the splines are good then more often then not you can get a longer slip yoke. Thats what I did on mine. Spicer parts of course.
Also K20's and ! tons have much better splines then the half ton shafts.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
