04-15-2010, 12:21 AM | #1 |
seat spring?
Got my bench seat back from the upholstrey shop today and found a large spring...loose...I do not remember where it goes..for that matter I don't remember it at all.... the seat tracks work great...where does this spring go?..passenger side?.........install seat tomorrow...thanks...J
04-15-2010, 12:38 AM | #2 |
Out of the carpool lane.
Re: seat spring?
That spring goes about half way between the ends of the seat and holds the 1/8" bar up (runs from track to track) so it doesn't sag. Does that make sense?
It looks kinda too long, but hard to get an idea of the size with no reference.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 04-15-2010 at 12:41 AM. |
04-15-2010, 12:46 AM | #3 |
Re: seat spring?
Sooo...it goes in the middle of the seat?..holds up the 1/8 bar...no sagging...ok..then it has nothing to do with the sliding of the bench, forward or back...except as you mention keeping the bar up and clear..thanks..makes sense...I will try it and find it's proper place tomorrow...70
04-15-2010, 04:31 AM | #4 |
Re: seat spring?
Is this the one your talking about? If so, here's a pic. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
04-15-2010, 05:52 AM | #5 |
Re: seat spring?
The spring pictured goes on the seat as an assist to pull the seat forward when you work the seat adjustment. It hooks to the seat track and the seat so that there is tension on pulling the seat forward. It can be seen in Dan's picture on the left.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 04-15-2010 at 05:54 AM. Reason: Added wording. |
04-15-2010, 08:43 AM | #6 |
Re: seat spring?
thanks...these comments and photo help
