Junior Member
![]() Join Date: Mar 2005
Now I can say I have a 12 second truck.
At the last minute I loaded up the truck and went to the track.It wasent crouded at all so I knew I would get a lot of runs.I still had 110 octane in the tank from the nitrous try last friday so I bumped the timing up to 38 total.First pass 13.10 1.82 60ft . Sec pass try again this time I bring my launch rpm up to 2800 insted of 2000 and it spun the tires. Third pass I lower my shift point to 5600 from 5800 13.05 1.88 60ft ? I think I'm on to something so I lower my shift point again to 5500 on the 4th pass and bingo 12.96 @ 101.82 ye ha!!! So the next pass I dont change a thing and backed it up with a 12.97 @ 101.87
I now have a 12 second truck. ![]() ![]()
72 cheyenne super BB402 TH400 Air Tack Tilt Posi P/S P/B AM/FM 12.96 @ 101.82 mph 60ft 1.82 12.39 @111.33 With a 180 shot nos 69 Camaro RS http://s94.photobucket.com/albums/l117/fdelcoglin/ email fdelcoglin@hotmail.com |
My Carbon Footprint
Re: Now I can say I have a 12 second truck.
Funny how once she quite building power....it's time to shift!
This was my best with a passenger. I was shifting at 7,700 ![]() |
![]() Join Date: Jan 2010
congrats on the 12 second slips
Right on!!
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#5 | |
I have been known to take a passenger but I don't thing I would take one on a pass that fast. What was this in?
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
My Carbon Footprint
Guys I'm so sorry. I was completely farting around last night. I have been battling the flu pretty bad and I think that was the NyQuil talking. That was a Pro Mod slip I found online. I have never and will never own anything that will pull 7's at 182.
My Birth Certificate has my legal name as Ima Wee Todd. When you look at power curves on dyno runs, when that curve tanks....she tanks fast. Imagine running an NFL drill where they have the rope tighed around the guy while he is sprinting. Now just imagine one little tug. Not only do you slow down, but it takes even more effort to get back to where you were. I can see 200-400 rpms in that fall off part really affecting a thenth or two and you are the proof. What's impressive to me is that these days, a 396/402 shouldn't even be called a big block. Not when you have 496, 505, 572 etc. Pretty darn cool right there. |
Junior Member
I think I was giving the original heads too much credit.
Congrats on the 12s!
Shawn
Shawn 85 SWB 7.39 @ 93 Best so far with 0 tuning Lesson in life: Never fry bacon naked! |
Congrats. What does your truck weigh?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
What tires you running? Nice passes by the way...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
Junior Member
Truck is 4500 lb with my big a** in it . Right now its a 275/60 mt drag radial.
VA72C10
![]() Join Date: Mar 2008
Congrats...time to update your signature!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#13 |
Junior Member
I just did
#14 |
Sweet man. Where the videos???
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#15 |
Mean Green
Nice job. I found that little trick out also end of last year. I stop winding the motor so high and go much faster. Odd how you have to slow down some times to go faster.
Once you get your truck to hook better, what you gain on the small end you will gain on the big end. So you will have an even faster truck once you tune on your launch. Congrats on the 12's
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. |
#16 |
Where you shifting 5,500 both the 1-2 and the 2-3? I've played around with shifting the 1-2 a little earlier and the 2-3 a little later/vise versa (talking a couple hundred rpms) and some times that works as well to pick up just a touch. Every combo is a little different.
#17 |
Congrats!!!!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
