Old 04-15-2010, 04:24 AM   #1
IndyRich
IndyRich's Avatar
TH 400 won't shift to 2nd or 3rd
Edit....Thanks to all who helped. I finally got around to messing with it and it was THE GOVERNOR!! Teeth stripped to nothing. A new Sonnax one $44 shipped to me,beats a rebuild
Hi everyone, so I'm driving home from Lowes and as I accelerate from a stoplight my truck (tranny) won't go fast than 25mph. It takes off like normal and then just revs higher when I hit 25mph and won't shift to 2nd or 3rd. I limped home and checked reverse, it works fine. No vacuum lines came off, fluid level was a little low so I added some, but that did not fix it. Would love to hear your input!
Questions:
1. What does the fact that 1st and reverse work mean? what can I eliminate because of that?
2. Some very small debris in fluid, what does that indicate?
3. If I pulled it to have it rebuilt, what is a "good" price for a TH400 rebuild?
Thanks in advance!
Rich
IndyRich is offline   Reply With Quote
Old 04-15-2010, 09:37 AM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: TH 400 won't shift to 2nd or 3rd
Questions:
Thanks in advance!
Rich
Check the vacume line that goes from the back of the carb to the modulator on the tranny... if its cracked anywhere it wont shift. It would act just like that if the rubber line is old and brittle. Id guess thats it.
Tom Vogel is offline   Reply With Quote
Old 04-15-2010, 10:09 AM   #3
67/72junkie
Remove side cover and check the govenor.It has a plastic gear on the end and when worn bad it will strip the teeth and tranny won't shift.I have had this happen to me twice over the years with th 400.This is second thing to check after vacumn line to modulator and modulator.
67/72junkie is offline   Reply With Quote
Old 04-15-2010, 10:13 AM   #4
fine69
fine69's Avatar
Sent you a PM.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 04-15-2010, 10:42 AM   #5
ShredSled
ShredSled's Avatar
yeah, I was going to say the shift governer too... side cover should be on driver's side above the rear mount...
get it!
ShredSled is offline   Reply With Quote
Old 04-15-2010, 11:05 AM   #6
Original67
Questions:
Thanks in advance!
Rich
#1 if I recall correctly are direct drive so nothing has to move to engage them is why they work.
#2 could be anything from normal wear (don't know when you changed it last) to a band coming apart. Hard to tell.
#3 this strictly depends on your location. There are people in OKC that will do it for as little as 300 up to 1K+ and it all depends on what you want in it.
Original67 is offline   Reply With Quote
Old 04-15-2010, 02:05 PM   #7
Tkmadone
I second the vacuum line check. Happened to me once too.
Tkmadone is offline   Reply With Quote
Old 04-15-2010, 03:38 PM   #8
Duncan and son
We have a guy in Lubbock (Jr Crump) that is the transmission daddy and if we pull it he rebuilds it and we put it back in he will do a complete professional rebuild on a turbo 400 for $450.
Hope that helps Paul
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
Old 04-15-2010, 08:09 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
go fire it up and drive it down the road, put the shifter in first... not drive.
Get up to 20 - 30 MPH, and then place the shifter in second.
If it shifts, then look at that vacuum line again... moth ends of it.
If it doesn't shift, then look into the GOv... and local rebuilders.
Old 04-16-2010, 02:38 AM   #10
IndyRich
IndyRich's Avatar
Well thanks for the input, did all you said. Vac lines are good, but replaced them anyway. Tried the shift thing from first at 25mph then to second and nothing happened. SO it looks like a governor or rebuild.
Old 04-16-2010, 10:01 AM   #11
neba
did you replace the modulator? what color is the fluid? if its brown it needs to be rebuilt. if not, other things to check.
neba is offline   Reply With Quote
Old 07-09-2010, 02:21 AM   #12
IndyRich
IndyRich's Avatar
Just an update....(I work on my truck in spurts. On two months, off another) Anyway.....it wouldn't shift or go above 25 mph.....IT WAS THE GOVERNOR!!! Thanks to all who gave suggestions. The teeth on the plastic gear were almost gone. A brand new Sonnex governor shipped to me was $44. Sure beats a rebuild!
Old 07-09-2010, 10:54 AM   #13
kwmech
Sometimes the rear bushing in the case will move back thereby stripping out the nylon gear. Check the bushing before you reinstall the gov'ner
