Old 04-15-2010, 06:26 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Adjusting shift indicator
I have an 85 with th350 and on the column it has the correct 3 spd indicator but for some reason it is off. When I am in regular drive(D) it is pointing to neutral. Is there some way to adjust the indicator or linkage?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 04-15-2010, 07:10 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Adjusting shift indicator
Yes - it has a little "edge clip" that clips to the side of the steering column bowl. You can scooot that clip one way or the other to adjust.
Incidently, we do that with the trans in neutral. Put the shift lever in Neutral and move the needle to "N"; that way you are more accurate in the middle and any error is moved to the ends of the travel (to L, which you don't use often, and to P, which is pretty robust).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-15-2010, 10:07 AM   #3
James McClure
One shot, one kill.
Also note, I would check the shift linkage under the truck where the goes from the trans to the frame. At the frame end there should be a teflon button with a spring behind it. The springs are noted to rust away leaving the linkage sloopy. The button will last forever. If you find this, remove the linkage and put a new spring in and adjust the linkage. Make sure trans is in neutral, make sure gearshift is in the neutral "gate", then tighten the linkage back up again. After that do what Keith said to do and you'll be good to go. Grease everything up good. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 04-15-2010, 10:36 AM   #4
softballnrd27
There isn't a spring or button to my knowledge, so I will look into getting one.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 08-05-2010, 05:37 PM   #5
joe231
joe231's Avatar
My bushing (button) is missing in action. You guys have any Idea where to get one? Maybe even a part number?
CHEVY ONLY
