Old 04-15-2010, 09:30 AM   #1
1quik70
NP 205 Problems???
I just picked up a 71 SWB 4x4, 454/TH350 combo, and had it shipped home. Once I started drving the truck I realized it had a tranny issue, it was shifting so hard it was border line violent. I narrowed it down to the modulator, and bought one to replace it. Yesterday heading to work, the truck shifted into 3rd and made the worst noise. It sounded like something in the transfer case let loose and is now moving around and grinding inside of it. The noise sounds like chain slop, but being there isnt a chain in this beauty, it can't be. It still shifts in and out of 4hi and 4lo no problem, and the truck still pulls hard through this, so the trany is out of the mix. The noise is definately in the transfer case. Any of you guys had something similar happen? Im going to pull the PTO cover tonight and see what I can see, but I've never messed with 4x4's?? Any advise or help will be much appreciated!
1quik70 is offline   Reply With Quote
Old 04-16-2010, 04:29 PM   #2
litebulblsc
litebulblsc's Avatar
Re: NP 205 Problems???
Sounds like a bearing might be going bad.
litebulblsc is offline   Reply With Quote
Old 04-21-2010, 04:11 AM   #3
skoffice
skoffice's Avatar
Maybe front driveshaft? Does it corelate to vehicle speed? I just found that my dad's is out in his K10. Sounded like a chain rattling around since its the dual u-joint style.
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 04-28-2010, 08:45 AM   #4
msgross
msgross's Avatar
I was guessing a u-joint as well... the transfer case in nearly bullet proof...
see if locking or unlocking the front hubs changes anything... that will cause the front driveshaft to spin. then look at the back shaft.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
