Old 04-15-2010, 09:37 AM   #1
rddaves54
rddaves54's Avatar
divorce choke spring help
72 Chevy 350 4bbl Q-jet.
Can someone show me picture of the divorce choke installed. I am replacing mine and the spring inside is not where the old one ends up (the old one is pulled apart some that is why I am replacing) so do I install the choke rod on the front side or the back side of the divorce choke spring?
Chief mechanic for my, 54 Belair, 64 Corvair, 72 C/10Fleetside and 2002Tahoe.
John 14:6 Jesus said, "I am the way, the truth, and the life. No one comes to the Father except through Me.
My Book "Why Cancer is Not Bad Luck" by WestBow press
rddaves54 is offline   Reply With Quote
Old 04-15-2010, 09:54 AM   #2
70k52wd
Blaze-Air
70k52wd's Avatar
Re: divorce choke spring help
I'll get a pic or two in just a minute . Brb.
70k52wd is offline   Reply With Quote
Old 04-15-2010, 10:19 AM   #3
70k52wd
Blaze-Air
70k52wd's Avatar
Hope these pics help out.
The first three are of my original carb. Last pic is a replacement carb.
Old 04-15-2010, 10:59 AM   #4
rddaves54
rddaves54's Avatar
The last picture is how mine was on but the new spring on the divorce choke is up front and I want to know do I pull the spring down and around so that the rod is coming up on the right side or do I pull it back across the top?. Pulling is back would unwind the spring a little and pulling it down would wind it tighter.
Which do I want the tighter spring or the looser?
Old 04-15-2010, 11:57 AM   #5
70k52wd
Blaze-Air
70k52wd's Avatar
I see what your asking for now...I think I would try lose first. It's easy enough to redo if it needs to go the other way(tight).
Old 04-15-2010, 12:52 PM   #6
rddaves54
rddaves54's Avatar
I turned it around because when it heats up the spring expands. It works because I started it cold and it kept the engine running. It now causes the engine to run at a higher rpm but it seems to be too high.
Is there an adjustment for the choke so the engine does not Run at too high a rpm?
Old 04-15-2010, 01:46 PM   #7
Fitz
Something tells me this is not what you had in mind:
Fitz is offline   Reply With Quote
