![]() Join Date: Jan 2001
Header Bolts
Does anyone have any recommendations for header bolts that are particularly good at holding on?
That's right, it's Copper!!
Re: Header Bolts
Tom: ![]() 1968 Chevy SWB ZZ383 W/700R4 Gen-II Compact Vintage Air System PPG paint, Mandarin Copper and Vanilla Shake. http://www.hubgarage.com/mygarage/fastom Stupid should hurt and eventually become fatal! |
Re: Header Bolts
Most brands are no better than others. I've always used off the shelf header bolts from the local auto supplier. They just need to be re-torqued 2 or 3 times of hot to cold cycling.
Be sure to use anti-seize on header bolts. |
#4 | |
Re: Header Bolts
They are by far the best I have used.
Life is short, so play hard!! |
![]() Join Date: Jul 2009
Re: Header Bolts
Totally Stainless sells something called a Total-Loc header bolt that's supposed to be really good, but they're kinda pricy.
Mike Mileski Tucson, AZ |
![]() Join Date: Aug 2001
Re: Header Bolts
if you use stage "8" header bolts with locks you'll never use anything else. They certainly are much much better. John
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Re: Header Bolts
I have found that on my big block truck you can use grade 8 bolts with lockwashers, but on small blocks I have used regular header bolts and drilled and safety wired them with no problems.
Re: Header Bolts
We sell Stage 8 header bolts- same part number $39.95 We can usually beat Jeg's or Summit prices on everything
Re: Header Bolts
im using the ones from autozone the one that had a head for a socket or allen wrench or whatever its called and they worked great
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
![]() Join Date: Jan 2008
Re: Header Bolts
I'm not exactly sure of the name, but the ones I use are 12 point stainless with an allen set screw in the middle, you snug your bolt, then tighten the set screw. They work great, and cost about 50 bucks, so you don't want to lose one. Good luck
Re: Header Bolts
I bought some off the shelf ones at a local hi po store that had 3/8" heads instead of 7/16. I put some loc-tite on them and they never came loose... And before you say it, I had no problem cracking them loose when the &%$# gasket flew south on me...
Re: Header Bolts
In the last 15 or 20 years i've had zero grasket failure, or never had to retourque them using stage "8" header bolts.
#13 |
![]() Join Date: Feb 2001
Re: Header Bolts
Simple remedy is a hack saw. Get the cheapo header bolts, tighten them and forget about them. Oh and get ya a set of manifold gaskets for about 7 bucks. No problems going on 20 years.
#14 |
Re: Header Bolts
i just use whatever comes with the headers mostly or buy stainless allen head bolts
i do routine maintenence like when i change oil i check and tighten header bolts clean and lube linkages and other moving parts check hoses etc
